exhaust setup
Old Nov 23, 2010 | 09:10 PM
juni88126's Avatar
juni88126
exhaust setup
I come to find out the hard way that power stroke exhaust manifold spacing is to wide for the idi motors. Can they be cut down in between the cylinders and then rewelded so that they would fit an idi motor? It was just a brain storm that i had while trying to figure out the exhaust.
Old Nov 23, 2010 | 09:14 PM
ihateminimumwage's Avatar
ihateminimumwage
Even if you could cut them down to fit and welded them, they'd crack in no time from the heat.
Just find the correct manifolds and bolt them in IMO...
Old Nov 23, 2010 | 09:37 PM
starmilt's Avatar
starmilt
What exactly are you trying to accomplish, using stroke exhaust,
Old Nov 23, 2010 | 09:42 PM
juni88126's Avatar
juni88126
i bought the turbo and exhaust from a 99 f250 and was going to try to use it on my 91 motor but hit snags with the exhaust
Old Nov 23, 2010 | 09:46 PM
johnboggs21's Avatar
johnboggs21
the manifolds are cast iron, correct? If so, cast iron is a b*tch to weld and probly wont last. Might be better off to tray to make some headers of your own....
Old Nov 23, 2010 | 09:48 PM
rodneywar's Avatar
rodneywar
or make your own uppipes like hypermax
Old Nov 23, 2010 | 10:01 PM
starmilt's Avatar
starmilt
There is a whole lot of snags to overcome trying to use a stroke turbo.
There have been several tried it and I don't remember anyone gettin her done.
89ford73
Oct 8, 2010 08:21 PM
alteredspeed
Sep 8, 2008 10:09 AM
nicebenz68
Competition
Aug 18, 2008 12:46 PM
