6.9 trans. Question
Old Nov 23, 2010 | 03:25 PM
Will Chiello's Avatar
Will Chiello
6.9 trans. Question
The 7.3 zf 5 speed has a one piece bellhousing and trans., but does a 6.9 have a seperate bellhousing
Old Nov 23, 2010 | 03:30 PM
Lazy K's Avatar
Lazy K
Not really sure what you are asking. The bellhousing has nothing to do with the engine. However if you are asking if the manual transmissions offered with the 6.9 engine had integral bellhousings then the answer is no, the bellhousing was seperate.
If you are asking if a ZF5 from a 7.3 will bolt up to a 6.9 then the answer is yes.
Old Nov 23, 2010 | 03:40 PM
catfish101's Avatar
catfish101
The ZF will bolt up behind a 6.9 but you have to do a few things to get them work behind one.
Old Nov 23, 2010 | 08:39 PM
Will Chiello
Thanks guys I did say that in a confusing way, it made sence because I was the one makling the question. But you did answer my question I was wondering if the 6.9 manual trans was a one piece bellhousing/trans, like the 7.3 trans. So the 6.9 transmission has a seperate bellhousing from trans. Correct?
Old Nov 23, 2010 | 09:16 PM
starmilt's Avatar
starmilt
Yes the manual behind the 6.9 motors is a 4 spd the integrated bellhousings are only on the ZF5 and 6 speeds and all the auto's.
Old Nov 23, 2010 | 10:32 PM
Marianna2003's Avatar
Marianna2003
So what do I need to do to put a ZF into my '85 in place of the 4 speed? Other than shorten the drive shaft, that is!
Old Nov 23, 2010 | 10:42 PM
catfish101's Avatar
catfish101
You are going to have to "basically" get a pressure plate for a 6.9 application and get a clutch disk for a 7.3 application to fit the input shaft on the trans. You are going to also have to take the throwout bearing fork and weld up the points of contact where the fork hits the throwout bearing. Going to have to weld it up about 5/16 to 3/8 of an inch because the flywheel housing is deeper on the ZF. I have done this a few times. There may be an aftermarket clutch kit to do this now but back when I did these I had to go to a clutch shop and have the disk made for it...It isn't to much trouble.
Old Nov 24, 2010 | 09:25 AM
farmert's Avatar
farmert
When I did this swap on my 85 4X4 I had a 93 donor. I used a single mass flywheel conversion from NAPA for a 93 7.3. It contains the flywheel, clutch disc, pressure plate, throw out bearing, pilot bearing and all new mounting hardware. Everything is a direct bolt up. I used the throw out bearing fork from the 93. The 208 transfer case from the 85 bolts to the ZF5 and the dirve shafts did not need altering. I used the floor hump panel from the 93 as the ZF is a little taller. I had to cut a new hole for the transfer case shift lever as it mounts different on the ZF. The lever came from the 93. Everything but cutting the new hole for the tc shifter was a direct bolt up.
eriksf250
Jan 15, 2013 04:44 AM
40dog
Apr 11, 2009 07:56 PM
BlueOvalDrifter88
Jul 19, 2006 06:59 PM
weedburner
Mar 15, 2005 07:40 AM
elrod2020
Feb 1, 2005 10:35 PM
