Sponsored by: Real Truck
grinding noise while turning slightly
Old Nov 23, 2010 | 10:47 AM
adam42481's Avatar
adam42481
After reading quite a few post that seem to be related I would like to get fresh prospective on my problem.
When driving slowly and truning the wheel a few inches to the left or right i get a grinding noise that seems to be coming for the front wheels. This problem is even worst if i drive in reverse and turn the wheels slightly. The problem only is noticable when your driving slow. When driving at highways speed if i let off the gas the truck pulls to the right. When i get back on the gas it straighten up.
I have check the brakes, ball joint, and axles to make sure they are moving freely.
I just purchased this truck about a month ago and have been having a lot of problems with it. which are for another post at a later time. Its 2003 f250 crewcab lariat 4x4, 5.4l, w/ 116k.
Any ideas? Thanks so much.
Old Nov 23, 2010 | 11:14 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Did you check your wheel hubs. Jack your truck up,grab the wheels with your hands on the top and bottom and wiggle it .If there's any play, they're shot.
Old Nov 23, 2010 | 11:43 PM
bmaruska's Avatar
bmaruska
Same thing happened to me right after I bought mine with 127,xxx
My driver side wheel bearing went out so I just replaced both my front hubs.
Old Nov 24, 2010 | 10:57 PM
socapots's Avatar
socapots
and as stupid as it may sound.. your wheels arnt touching antying.. fender.. mudflaps..
sometimes over looked.
Old Nov 29, 2010 | 07:49 AM
adam42481's Avatar
adam42481
thanks for the suggestions. I did jack up the truck and wiggle the tires and nothing. Also i looked for anything rubbing and didnt see anything. So i decided to just take it to the shop and see if they could find the problem. They call this moring and they couldnt find anything wrong. They stated that it is probably the tires. the tires are dunlop rover rvxt which have about 2000 miles on them. they dont have an aggrive tread on them at all. I guess I will just drive it till they are ruined. Thanks for the advice
mike's1980f100
Nov 17, 2013 10:41 AM
V10FarmTool
Feb 28, 2013 07:44 AM
smokinquack89
2004 - 2008 F150
13
Oct 16, 2009 07:29 AM
MikePDX
2004 - 2008 F150
Dec 27, 2007 11:21 AM
