01 Ex w/ 7.3 Truck started running rough and limped home the last mile about 5 mph. Won't start at all now. AE scanned P1316 injection drive module; P1280 ICP sensor low; P1690 wastegate solenoid circuit; P1316 injector driver module codes detected; P1119 manifold air temp circuit high input. Any ideas .... do I replace it all? Fuel bowl fills pretty quick.
You more and likely have a loose under the valve cover plastic connector/s that controls your injectors and glow plugs.. SEE the following link to fix it... with two quarters and a little labor... https://www.ford-trucks.com/forums/8...ck-shakes.html
Welcome to the forum..!!
Great news. Now maybe tell your wife that you want her to get you a supporter badge for this great new website you found that just saved you a thousand or so dollars?
And I agree with Clint. Much better to do the passenger side now on your own terms rather than a more inconvenient time later. But it does make you feel good about being able to fix something so complex with such an easy method, doesn't it? Hang around and you'll be amazed at what else you can learn here.
