PLEASE HELP!!!! Engine start issue, 5.0l
Old Nov 22, 2010 | 09:35 AM
chrisroy1972's Avatar
chrisroy1972
Exclamation PLEASE HELP!!!! Engine start issue, 5.0l
Hi everyone! i am hoping that you guys can help me with my problem.
i have a 1990 f150 2wd 5.0l. i just completed reassembly of the motor after changing the head gaskets. i double, triple checked all connections and vacuum lines, fuel lines, wiring, etc. when i crank it seems like it is struggling a bit. i marked the rotor and the ditributor position but i admit that i did not double check rotor position when i installed the distributor. i labeled everything and installed all new engine sensors and computer so i think those things are ok. when i took the a/c compressor off, the belt did come off dont know if that makes any difference or not.
does anything jump out at anyone?
Old Nov 22, 2010 | 12:30 PM
rla2005's Avatar
rla2005
From my good buddy Scott over at Fullsizebronco.com: How to properly set the timing on a 302 or 351
