name that part
Old Feb 28, 2003 | 04:19 PM
F-Econolines's Avatar
F-Econolines
name that part
Gents...1986 E-350, 6.9, C-6....my trans shifts on the high side like 35mph and then 55 mph. ( always those speeds no matter how much or little throttle). It stays in first till 35 or I shift manually and then second between 35 and 55 mph. The old trans did the same ( I installed this rebuilt 2 months ago).
I found a .................?? on the injector pump. It resembles a throttle position sensor on an EFI vehicle except it has vacuum in and out going to my modulator valve. A test with a vacuum pump shows this part N/G.
I am looking to replace this part as a starting point. Does anyone know the name and if it is available other than a dealership???
Thanks ...Al
Old Feb 28, 2003 | 08:02 PM
wolfmanagh's Avatar
wolfmanagh
name that part
I don't know what the part is called, and my book is at the shop so I can't look in there. But is this the part?
Old Feb 28, 2003 | 08:24 PM
F-Econolines
name that part
Thank you Andrew...that is exactly the part...you mention "the shop". is that a FoMoCo dealer or???...Al
Old Feb 28, 2003 | 08:30 PM
wolfmanagh's Avatar
wolfmanagh
name that part
No, its a non-profit org.. I have my idiot manual over there, cause I use it more there then at home.
That injector is one I had in my basement from an 84. I couldn't see throwing it away with the truck.
Old Mar 3, 2003 | 08:11 PM
psd tech's Avatar
psd tech
name that part
I believe the p/n you need is E5TZ-7B200-A It shows as a good p/n through Ford. It will cost you around 75-100 dollars through Ford. It is a vacuum controll valve. Hope that helps you.
RC Dan
Sep 13, 2022 06:35 AM
OldCharro
Apr 20, 2015 09:36 PM
dakotajeep
Jan 17, 2014 06:17 AM
TheKirbyMan
18
Jan 10, 2012 01:04 AM
Hybrid455
Sep 6, 2009 07:08 AM
