what cam?
Old Nov 22, 2010 | 01:41 AM
dsands88's Avatar
dsands88
what cam?
Just looking into what cam would work best in my 1988 f250 single cab lb 302 I have 35" tires to put on it soon aswell. thanks dylan
Old Nov 22, 2010 | 07:04 AM
L. Ward's Avatar
L. Ward
Comp Cams has some that are compatible with the factory efi, but without some gearing changes or major work, any gain you make from doing just a cam change will be more than offset by adding a set of 35" tires
Old Nov 22, 2010 | 07:20 AM
jrwhitmire's Avatar
jrwhitmire
I agree with that, but I don't have any experience with an F250 w/5.0. I would hope the factory would have shipped them w/ 4.10's.
dsands88, do you know your gear ratio? If you only have 3.55's, you'd probably be better off spending the money on gears, do the cam later.
