Sway bar ?
Old Nov 21, 2010 | 08:15 PM
732t37's Avatar
732t37
Sway bar ?
I drive a 1991 f150 rear wheel drive, which has no sway bars and never did. I occasionally tow heavy (~2500#) loads, but I use it mostly for commuting in the city.
I recently acquired a REAR sway bar from a 1986-91 Bronco for free, from my job at the boneyard.
Seeing as how it would cost me the same ($0 + labor) to use it or not, should I install it? Would it be worth the effort to remove the FRONT sway bar from the Bronco, which is now sitting on the brake discs and could kill me if I tried to jack it up? I guess some of us live and die by Ford lol, but I personally am not keen on jacking up vehicles sitting in soft mud.
Old Nov 21, 2010 | 10:19 PM
Conanski's Avatar
Conanski
Front sway bar only on a pickup is fine but rear bar only is a handling disaster, so you want both or none at all.
Old Nov 21, 2010 | 10:25 PM
85e150's Avatar
85e150
x2
"never did"? Should have at least had a front bar as OEM.
Old Nov 21, 2010 | 10:35 PM
SideWinder4.9l's Avatar
SideWinder4.9l
What all entails installing front/rear s-bars on a truck originally without? What kind of benefits will I see, aside from better maneuverability ?
Old Nov 21, 2010 | 10:36 PM
PatsPOS's Avatar
PatsPOS
For what it's worth, my brother's '91 half-ton doesn't have sway bars on either end. I can't for the life of me figure out why Ford did that...even my dad's '50 Ford business coupe has a FRONT bar!
Pat
Old Nov 21, 2010 | 10:55 PM
SideWinder4.9l
Mine doesn't either....then again it IS an XL......
Old Nov 22, 2010 | 01:56 AM
TexasGuy001's Avatar
TexasGuy001
Most of our trucks didn't come with sway bars.
Don't run just a rear one. I would keep the rear though and save it for when you get a front one.
I added them to my truck and can say that its a huge improvement.
Old Nov 22, 2010 | 10:46 AM
Hitokori's Avatar
Hitokori
my 88 xlt lariat didnt have front or rear sway bars...
so i took the front and rear ones off my dads 86 f250 because he doesnt drive it anymore
Old Nov 22, 2010 | 12:14 PM
SideWinder4.9l
I really am interested in installing the front and rear anti-sway bars for my truck, LMC Truck sells the 2wd sway bars for $179, and the end link assembly is sold seperately....My question is how that I actually install it to the truck, what it actually attaches to, etc...
Old Nov 22, 2010 | 08:44 PM
Ed Bamba's Avatar
Ed Bamba
Just for the record, my 91 F150 XLT Lariat Supercab, with factory trailer towing package came with front and rear anti-sway bars.
Old Nov 22, 2010 | 10:30 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1
would f-150 sway bars work?
Old Nov 23, 2010 | 02:22 AM
TexasGuy001
The rear factory sway bar is easy to install. The factory front is a bit more invloved. I just bought a Hellwig for the front.
Old Nov 24, 2010 | 12:20 AM
85e150's Avatar
85e150
Factory mounts may differ from Hellwig, unless the Hellwig is to replace a stocker. My rear bar for the E150 had the link mounts clamp to the frame.
Old Nov 24, 2010 | 12:44 AM
TexasGuy001
The factory mounts are different than the Hellwig mounts. Thats why I bought the front one from Hellwig. It was much easier to install. To add a factory front one, the spring has to be removed and the end link bracket mounts under it to the radius arm and I beam.
In the rear they are different but I think they mount to the same location.
Joel Cassell
Jan 12, 2018 10:55 AM
savagebagz
Aug 7, 2016 09:08 PM
79Supercab
Feb 11, 2015 04:14 PM
MR KROGOTH
Dec 19, 2012 06:07 PM
Sycostang67
Sep 9, 2010 08:05 PM
