heater problem
Old Nov 21, 2010 | 05:27 PM
warfalcone's Avatar
warfalcone
heater problem
new here just wanted to say hi to everyone. I have a 95 250 7.3l turbo 5 speed. the problem is no heat right now. i turn the dial to heat and it is cold, turn it the other way and colder. any info on this would be great
Old Nov 21, 2010 | 06:47 PM
Psykoemaniac's Avatar
Psykoemaniac
I have a similar problem and from what I've been reading it might be a blend door issue which can break with age since it is plastic. Not sure if this pertains specifically to you but maybe it's somewhere to start looking
Old Nov 21, 2010 | 08:38 PM
dieselaholic's Avatar
dieselaholic
had a similar problem on my 92. Before i got my truck the head gaskets were blown so they put blue devil (water stop leak) to cure it but in the process if plugged off heater core. relplaced heater core and hot hot heat.
Old Nov 22, 2010 | 02:10 AM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Get the motor up to opp temp. Then pop the hood. Feel the two hoses going to the heater core. If one is warm / hot and the other is cool / cold Then chances are your core is plugged. IF there both warm / hot its a blend door in the duct work. If there both cold check water level and that hoses are hooked up.
Old Nov 22, 2010 | 03:03 AM
Psykoemaniac
Ooo I'll have to do that tomorrow before I start taking screws out of my dash! Thanks Ohio Ford Farm!
Old Nov 22, 2010 | 12:56 PM
warfalcone's Avatar
warfalcone
Thanks guys I do believe it is the blend door .can I just get I new one or does it come as one whole unit?
Old Nov 24, 2010 | 03:12 AM
Psykoemaniac
You can just buy the part or even repair the part.. I found a website by googling but it didn't pertain to my case, mine is cable controlled while the website was describing actuator controlled.
Best of luck!
Old Dec 15, 2010 | 07:45 PM
Giftsbuyus's Avatar
Giftsbuyus
We had the same problem on my '92 150 with a L6 w/out A/C a friend on mine showed me a vacume activated valve on top of blower box under the hood. That was not working when we adjusted the temp. We pushed the rod in,it was stuck full out. On the way home it was good and hot in the cab. It was about 34 out. This am it was about 14 outside and 18 in the cab..LOl
One hose was warm and the other hot befor. I don't know now that we opened this. I can still adjust the temp to cold and hot. He had said on his 86 the same valve is in line with the heater line. It is silver with the hard type vacume line running to it. I hope this helps.
