UP Ppe install
Old Nov 20, 2010 | 08:37 PM
bakerbuilttracks's Avatar
bakerbuilttracks
UP Ppe install
I have searched for a thread on the up pipe install and couldent find anything. Done anyone have a good write up on installing the uppies.
Old Nov 20, 2010 | 09:11 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Here you go.
Welcome to Pocket's International UP-Pipe Replacement Web Page
I found it helpful to bolt the passenger side pipe to the collector (baby's butt) on the workbench and then stick it in the proper location. Then bolt the lower end to the passenger side exhaust manifold but leave the bolts very loose. Then install the driver's side up-pipe, start the upper and lower bolts and then find 3 or 4 long extensions and a universal joint and reach wayyyyyy up to the back side bolt for the connection to the collector. You can reach this from underneath the truck. When the 4 bolts are tight on the collector (baby's butt), then install your turbo.
Next, I then loosened or even removed the lower bolts at the exhaust manifolds so I can lift the up-pipe assembly and mate it to the turbo inlet properly. There is a dowel pin that is hard to get aligned if your have the lower bolts in place. You can 'feel' when the dowel pin finds home...when that happens, hold the collector in place and install the clamp. Keep pressure on the clamp and you will ensure the dowel won't move and tighten it up. Don't over tighten or you'll break that clamp. Then go back down under the truck and reconnect the pipes to the exhaust manifolds and you are nearly finished.
Hope this helps.
Old Nov 20, 2010 | 09:19 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here ya go, This should help.
AAHHH Greg beat me to it
Old Nov 22, 2010 | 08:36 PM
bakerbuilttracks
Its ok Rich it wasnt a race hahah Congrats on the 1st Greg. Thanks Again guys hopfully i can get them done soon. Im Supprised Clay hasent chimed in to give me a price yet. Guess I will have to PM him haha
Old Nov 22, 2010 | 09:14 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Ok, ok, I am here . Here is a link for you.
Riffraff Diesel: IH Bellowed Up-pipe Kit
Zachthemoo2
Oct 7, 2014 10:30 AM
Juddpease
Sep 10, 2014 04:33 PM
rb8484
Oct 18, 2010 12:29 PM
smokem331
Aug 2, 2007 09:40 PM
DeckedoutF150
Computer Chips & Tuners
Jan 31, 2006 03:57 PM
