tranfer case problem
Old Nov 20, 2010 | 07:53 PM
Waterwizard's Avatar
Waterwizard
Just purched 83 F-25 4x4.Transfer case slips out of gear in 2H 4H but not in 4L what needs done linkage adjust or rebuild
thanks in advance,John
Old Nov 20, 2010 | 08:15 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
On my BW1345, the linkage isn't really adjustable that I recall. You might crawl under there
and see if your linkage is just plum worn out and the holes have been made into ovals (for
example) but I for some reason doubt the linkage has anything to do with it popping out of
gear.
Old Nov 20, 2010 | 10:07 PM
Franklin2's Avatar
Franklin2
If you have a body lift, make sure the lever is not hitting the floorboard, it has been known to happen. Also make sure the motor mounts and the rear tranny mount are good and not broken. When I did my tranny swap in my 89, the rear mount was completely broken away, and the tranny/transfer case were just sitting there, gravity holding them in place. It's hard to tell this unless you put a pry bar under it and lift it.
62FE4x4
Apr 16, 2012 10:47 AM
John Boyd
Aug 25, 2005 06:24 PM
Lifted78
Sep 6, 2004 11:30 AM
