success!!!!!!!!!!!!!!
Old Nov 20, 2010 | 06:54 PM
limptera13's Avatar
limptera13
for those of you who have been following my agonizing project im finally done, after doing the trans swap and then screwing up the oil pump shaft its all back together n i had it runnin n driving round the block for like n hour today.
i still have a slight oil leak thats running from transmission bellhousing, my neighbor said the rear main seals even when replaced stil suck, so im asssuming its that, or maybe the oil pan has a slight bend in it. i dont have to do it again cause the drip isnt that bad, im gonna run a lil heavier oil in it.
shifts good ina ll 3 gears, tomorrow i will test drive it at higher speeds. i probably got up to like 40 45 today, hard to tell without a speedo as goin from manual to auto
Old Nov 20, 2010 | 07:18 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Congrats! Hopefully, it will give you years of good service.
