Cam Help, Suggestions
Old Nov 20, 2010 | 05:35 PM
aj197816134's Avatar
aj197816134
I may have to get a new cam for the motor build. The engine is going back in a 95 F 150 5.0L Auto 4x4 Single cab with 8 foot bed.
Have a roller block, with E6 Heads, and pistons for it. My donor block will need some machine work to the cyls, not happy with the surface. In any case my cam was rusted, waiting to see what machine shop says about it Monday. While looking on summit, I have tons of Hydr. Roller cam choices. Any suggestion, on specs for a DD pickup, that will haul the occasional loads? Lift, Duration etc? I see some "trick Flow" and Ford Motor Sports cams,
What would you recommend?
Old Nov 20, 2010 | 06:39 PM
Freaksh0w's Avatar
Freaksh0w
What do you want out of your truck?
Old Nov 20, 2010 | 07:07 PM
aj197816134
It will be for a relative. DD, close to OEM, maybe a little bump in TQ or economy. mainly just a daily driver
Old Nov 20, 2010 | 07:42 PM
Conanski's Avatar
Conanski
Comp 35-512-8.
Old Nov 20, 2010 | 07:49 PM
393STROKER's Avatar
393STROKER
You can call Competition Cams tech support and tell them what you have to work with and what your goals are and they can hook you up with an off the shelf cam or even a custom grind.That`s what I did,and I`m happy with the cam that I`m using.
Old Nov 20, 2010 | 09:22 PM
aj197816134
Never knew I would get so deep in a project. I thought I had cam for the TK, then realized it looked identical to the "car" cam and the first 2 lobes were different.
cha Ching $$
