Sponsored by: Real Truck
huh?
Old Nov 20, 2010 | 04:07 PM
Mike F250 SD's Avatar
Mike F250 SD
huh?
Ok here's what happened. I was pulling a smaller stump out of the ground after I had dug around the base pretty well.I pulled it out without even hitting the gas. I put it in reverse and hit the gas, it felt like my truck was hung up on some thing and would barley move. I was in 4x4 low, I tried to put it in park and it made some weird tapping clanking sound. I put it in N and put out and back into 4x4 low, same result. 4x4 H no probs 2wheel no prob? Truck shifts good no probs ever like this. I'm lost on what it could be. I have a 2004 F250 4x4 5.4l manual 4x4 and manual lockers
Old Nov 20, 2010 | 05:11 PM
Tom's Avatar
Tom
It could be that the truck isn't all the way engaged in 4-low when this is happening. I'd play with the lever for a bit to see if there is any change.
Otherwise you likely have something broken in your transfer case. I'd have a good transmission shop look at it and see what's broken.
Old Nov 20, 2010 | 05:21 PM
senix's Avatar
senix
sounds to me like you needed to move the truck to fully engage 4 lo.
Old Nov 20, 2010 | 06:44 PM
KC8QVO's Avatar
KC8QVO
Don't you have to put it in reverse to shift it out of 4x4 in a manual, like you can't pull the shifter and keep on driving because the gears won't kick out... Not sure if this has anything to do with it, but something to think about I guess. My last truck was ESOF, same with my new one.
Old Nov 20, 2010 | 06:49 PM
senix's Avatar
senix
i put mine in n ( trans) and then it comes out.
Old Nov 20, 2010 | 08:33 PM
Mike F250 SD
I though it wasn't in all the way too, but I tried and tried...
Old Nov 21, 2010 | 11:59 AM
exiled's Avatar
exiled
Are you pressing the brake petal? There's a switch on the brake that locks out 4L if the brake isn't pressed in.
Old Nov 21, 2010 | 01:48 PM
Mike F250 SD
Good question.. I was tryin to hurry up so I could have forgot.. I'm gunna go try again
Old Nov 22, 2010 | 12:13 AM
Thunderduckie's Avatar
Thunderduckie
I'm curious about this issue. I have an '03 5.4 with an auto and my issue seems to be a bit similar. I can go from 2wd to neutral to 4hi with no issues. However, I have to put the truck in neutral, turn of the ignition, pull the truck into 4lo and then refire. I have the manual 4x4 selector and manual hubs. If I don't turn the truck off it makes a horrible grinding/whinning sound. I asked the dealer and the said that this is a common issue.
Old Nov 22, 2010 | 01:00 AM
exiled's Avatar
exiled
The rachet noise or having to turn the truck off? Yes its normally to hear racheting sounds as the trasfer case locks up. I don't know anybody that has to shut their truck off. 1 thing yall are leaving out is the brake. You have to have the brake pressed to get into/out of 4L. Sorry it just won't go any other way. 4H is different.
Old Nov 22, 2010 | 03:12 AM
TexasRebel's Avatar
TexasRebel
yep, unfortunately somewhere between the brake lockout, and needing to roll forward while engaging it sounds like you aren't getting the gears meshed.
every 4x4 I've driven took a little effort, some grinding, and a little gear rolling to get 4L engaged.
