Oil Cooler Replacement
Old Nov 20, 2010 | 05:37 AM
mcboudreaux's Avatar
mcboudreaux
Hey guys, I've got a 2005 F250 HD with 80000 miles on it. I'm gonna pull the cab in a few months to address the usual 6.0 problems (ARP studs, EGR delete, turbo drain tube, etc) I've looked at oil cooler replacement also. The relocating kit is pricey. My question is about the ford part. Does anyone know if the ford part is an updated design or would I be putting on the same thing? And if it is re-designed, does it work as well as the relocating kits?
Old Nov 20, 2010 | 06:28 AM
npccpartsman's Avatar
npccpartsman
Adding a coolant filter and changing to ELC coolant helps tremendously with the oil cooler "problem". The factory design works very well. IH doesn't seem to have all the cooler failures that Ford does. There are folks on this forum that don't run a coolant filter that haven't had problems although they may just be lucky. There are people that do that have had multiple coolant failures and they may just be unlucky. I'm running the bulletproof setup and my truck loves it. Pricey, yes, but very high quality and you never have to worry about it again.
