Must use a 4x4 four speed trans in a 4x4 and a two wheel drive 4speed in a 2wheel drive.
I believe the trans cross member is different.
You will have the cut the floor board out and install a manual trans floor hump cover. Get the cover and trace it out and cut carefully.
Need to change out brake pedal to a clutch and brake combo, will easily bolt in.
You will need the cross over shaft and linkage to work the clutch fork.
You will need a different drive shaft or front yoke if two wheel drive.
