newbie intro and help
Old Nov 19, 2010 | 08:45 AM
parkers5150's Avatar
parkers5150
thanks for the heads up on the trans. section of the forums. i know some sites frown on double posting so i'll see if i can get'er done here. if not i'll slide over there
Lazy K's Avatar
Lazy K
The cover is forward of the trans pan but behind the engine oil pan and bolts up to the bellhousing and is, more than likely, black plastic.
Old Nov 19, 2010 | 08:47 AM
parkers5150
gonna get dirty will report back asap
Old Nov 19, 2010 | 09:10 AM
parkers5150
eureka! couldn't see it for the crud! can you please describe to me in detail the procedure for exposing the plug. also the chilton book says use only Mercon tranny fluid. i told the guy at Kragen this and he sold me Premium tranny fluid (house brand) that has a rather ambigous description on the label as to what its uses are
Old Nov 19, 2010 | 09:21 AM
Lazy K's Avatar
Lazy K
Drop the cover, rotate the engine until the converter drain bung comes round to the 6 oclock position, remove bung, let converter drain and replace bung. You will also have to drop the pan, clean it and the filter and refit, do not over tighten the pan bolts. Refill with fresh fluid.
The fluid should meet Dexron3/Mercron specs. Should say on the container if it meets DexronIII spec.
Old Nov 19, 2010 | 09:28 AM
parkers5150
thanks K, will let you know
Old Nov 19, 2010 | 09:39 AM
parkers5150
so I'm not having much success finding the drain. at present i can see a small bolt (3/8 7/16???) but it would seem to me too small for a drain
Old Nov 19, 2010 | 10:23 AM
parkers5150
got it!! thank you so much. it was the small bolt. while i was under there i noticed engine oil that is coming down the exhaust manifold is this as bad as i suspect?
Old Nov 19, 2010 | 11:34 AM
parkers5150
so i've drained the pan changed the filter, drained the TC. to refill system do i add some fluid then start motor and add till desired ????? what is the correct procedure???
Old Nov 19, 2010 | 12:30 PM
ottawaguy's Avatar
ottawaguy
When I did mine, I filled it to the proper levels and then started the truck and ran it for 10-15 seconds if I recall correctly. This will allow the fluid to fill the TQ.
Then re-check fluid and add as necessary. Again, this was for a different transmission, but I suspect the TQ will fill the same way.
frosty38506
Tennessee Chapter
Jul 30, 2013 01:41 PM
paintballergb
New Member Introductions
May 18, 2012 02:01 PM
Lushman
30
Sep 19, 2011 07:32 PM
catrepair
Jul 21, 2004 01:58 PM
Agapemou
S. California Chapter
Sep 10, 2003 03:28 PM
