brake lights
Old Nov 18, 2010 | 07:17 PM
jacksonford's Avatar
jacksonford
brake lights
i have a 1979 f150 ranger xlt, all lights work until u turn the headlights on then the right side blinker wont work or light up. is it the headlight switch,blinker switch or something else.please help
Old Nov 18, 2010 | 08:06 PM
70 Bronco TX's Avatar
70 Bronco TX
Had the same problem, tried everything...bottom line is I needed a new $8 light socket.
Old Nov 19, 2010 | 01:19 PM
jacksonford
new headlight switch
put new switch in and it did not help does anyone know if it could be the blinker switch?
Old Nov 19, 2010 | 01:21 PM
Nathan Plemons's Avatar
Nathan Plemons
Since it works part of the time and you've got somebody saying they had the exact same problem and fixed it with an $8 socket, I think I'd try that first.
Old Nov 19, 2010 | 01:51 PM
Joseph69's Avatar
Joseph69
x3 on light socket, the ground at the tip rusts off!
Old Nov 19, 2010 | 02:20 PM
70 Bronco TX
True...
The left rear blinker and brake light wouldn't work when the headlights were on.
I tried a new headlight switch, turn signal switch, brake switch (less than a year ago) and bulbs. Didn't fix it. Traced the wiring and made sure all grounds I could find were OK, including the ones at the front where the headlights and front turn signals are. A cheap $6 circuit tester works well enough.
Put in a new socket and it fixed it. (I had tried that first, but didn't work...I'm thinking it was bad to begin with, or I had the bulb in wrong as the aftermarket jobs let you put it in either way. Bought a second one and it cured my problem.)
Old Nov 19, 2010 | 06:57 PM
jacksonford
going to try new sockets in the morning,i"ll let you know how it goes. thanks for the help
Old Nov 20, 2010 | 01:11 PM
jacksonford
put new sockety in and everything worked great. thanks for the help
