Exhaust ticket
I gotta ZF6, with no cat. Did have a muffler though. Straight piped mine, and unless yuor into the turbo, doesnt sound loud at all, to me, though i do get outta the go pedal when seeing/passing the coppers.
Question Timmyboy: Did you notice any additional noise over stock in the cab itself? I don't care about increased noise at the tailpipe but was wanting to test drive a straight piped truck before installing a 4 inch staight pipe down the road.
not at all, homeboy. What i mean about, hearing it, being "in the pedal", is nothing more, than the whistle, contributed to the intake and W.W. wheel, at higher rpms, other than that, with her moving, cant tell the difference. Think the only difference, is at idle, with exhaust blowing to ground, somewhat gives an echo effect, but no noticable difference, from inside the cab.
If i did it over again, i'd "cut" the muffler out, and install a straight pipe there, with 2-exhaust u-bolt clamps, and leave the rest of pipe run'n out the back. So, for when time to smog, just unbolt, drop it out, and install muffler.
My wife's truck is straight piped and I can definitely hear a difference. It's a bit annoying on the highway but doesn't sound bad when just driving around town. I am looking for a muffler to install when I get the time.
Ok, I guess I really need to drive a straight pipe truck before doing it. Sounds like some don't notice much of a difference while others do
#29
The exhaust at cruising speed can be a bit loud on stock tires and no stereo. Now with 38s the exhaust noise is the last thing i notice on the highway. Most of the time i hear the exhaust is driving through town and mashing it.
Chet i don't think you can legally change if you had a cat or not. In california you need to have one if your truck came stock from the factory with it. What year is your truck?
#30
