Exhaust ticket
Old Nov 18, 2010 | 11:41 PM
4inchlovin's Avatar
4inchlovin
If you were to read Ca. vehicle code book cover to cover you basically could make the statment that anything after market on or done to your vehicle is illegal. Unless its CARB approved.
Old Nov 18, 2010 | 11:58 PM
Sheldon Plankton's Avatar
Sheldon Plankton
Originally Posted by TP83
.....What exactly is a CS cite?....
I believe that "CS" refers to poultry excrement.
I hope I'm wrong, but I suspect that fighting it will cost more than paying the ticket. The system is rigged and this is nothing more than a legal shakedown.
Old Nov 19, 2010 | 12:08 AM
Stewart_H's Avatar
Stewart_H
Yep. Chicken poop, with an "S"
Stewart
Old Nov 19, 2010 | 05:30 AM
RKern's Avatar
RKern
I was a cop for over 30 years. Muffler tickets in this part of the country are either CS tickets or attitude tickets. In this area the tickets are considered defective equipment tickets and do not go on your driving record. Generally you will be ordered to correct the violation.
Old Nov 21, 2010 | 12:15 PM
TP83's Avatar
TP83
What companies make carb approved mufflers? I don't have the stock one and my buddies all tossed their too.
Old Nov 21, 2010 | 12:48 PM
timmyboy76's Avatar
timmyboy76
Originally Posted by Stewart_H
4R100 = From the factory, no cats
ZF6 = From the factory, it came with cats
I gotta ZF6, with no cat. Did have a muffler though. Straight piped mine, and unless yuor into the turbo, doesnt sound loud at all, to me, though i do get outta the go pedal when seeing/passing the coppers.
Old Nov 21, 2010 | 01:11 PM
cavitation's Avatar
cavitation
Question Timmyboy: Did you notice any additional noise over stock in the cab itself? I don't care about increased noise at the tailpipe but was wanting to test drive a straight piped truck before installing a 4 inch staight pipe down the road.
Old Nov 21, 2010 | 01:37 PM
timmyboy76's Avatar
timmyboy76
not at all, homeboy. What i mean about, hearing it, being "in the pedal", is nothing more, than the whistle, contributed to the intake and W.W. wheel, at higher rpms, other than that, with her moving, cant tell the difference. Think the only difference, is at idle, with exhaust blowing to ground, somewhat gives an echo effect, but no noticable difference, from inside the cab.
If i did it over again, i'd "cut" the muffler out, and install a straight pipe there, with 2-exhaust u-bolt clamps, and leave the rest of pipe run'n out the back. So, for when time to smog, just unbolt, drop it out, and install muffler.
Old Nov 21, 2010 | 05:04 PM
Stewart_H's Avatar
Stewart_H
You bought your truck brand new?
If yes, yours would be an anomaly, according to my understanding of how Ford spec'd the trucks out.
Stewart
Old Nov 21, 2010 | 05:22 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My wife's truck is straight piped and I can definitely hear a difference. It's a bit annoying on the highway but doesn't sound bad when just driving around town. I am looking for a muffler to install when I get the time.
Old Nov 21, 2010 | 05:37 PM
cavitation's Avatar
cavitation
Ok, I guess I really need to drive a straight pipe truck before doing it. Sounds like some don't notice much of a difference while others do
Old Nov 21, 2010 | 07:02 PM
bigbubba87's Avatar
bigbubba87
i have stacks but even when i had exhaust out the back my truck was not that loud even when i got on it. There was more noise from the whistle of the turbo under the hood then there was out the exhaust.
Old Nov 21, 2010 | 08:17 PM
  #28
Bonanza35's Avatar
Bonanza35
Stewart, in feb.99 ZF6 equiped trucks had know cat. I have the auto and it has a cat. Would like to figuire out how to change that legally, any answers please, please let me know, Chet
Old Nov 22, 2010 | 11:52 AM
  #29
TP83's Avatar
TP83
The exhaust at cruising speed can be a bit loud on stock tires and no stereo. Now with 38s the exhaust noise is the last thing i notice on the highway. Most of the time i hear the exhaust is driving through town and mashing it.
Chet i don't think you can legally change if you had a cat or not. In california you need to have one if your truck came stock from the factory with it. What year is your truck?
Old Nov 22, 2010 | 12:56 PM
  #30
Bonanza35's Avatar
Bonanza35
My truck is a e99 built 9-98. My neigbors is 99 built 10-2-99. He has a ZF6 trans. no cat sure would be nice to get rid of that cat for towing reasons, keeps the EGT down without it, Chet
