4.6 crankshaft compatabilty
Old Feb 27, 2003 | 11:41 PM
cdrtrider's Avatar
cdrtrider
I was wondering if ford used the 8 bolt crankshaft (on the flywheel side) in a 1997 F150 I think 6 bolt was only in cars am i right im thinking about fixin up my 4.6 with a forged crate short block so i need to know
Old Feb 28, 2003 | 10:20 PM
wmcnally's Avatar
wmcnally
cdrt,
You may find the answer here: http://www.musclemustangfastfords.co...MMFF_MixMatch/
Old Mar 1, 2003 | 01:20 AM
cdrtrider's Avatar
cdrtrider
Thanks for the reply but it not what im lookin for. what else is differnt about an f150 v/s mustang gt 4.6liter will the intake change out is it the same wireing harness i know the heads would but the crank has got me realy confused 6 bolt or 8 bolt flywheel because i would like to keep my transmission
Old Mar 1, 2003 | 09:57 PM
cdrtrider's Avatar
cdrtrider
Ok on the valve cover is a bar code wich contain the engine code engine number and the build date the engine codes are REP and WEP . Rep have an 6 bolt flywheel and WEP has a 8 bolt flywheel.
Old Mar 3, 2003 | 12:33 AM
Zinc_00_GT's Avatar
Zinc_00_GT
Up grading your short block will not mean you need a new tranny even if the crankshaft is the wrong bolt pattern you would just need a new correct flywheel. In the grand sceam of things that would be cheap compared to the 2500 to 4500 your thinking of spending on that mustang short block.
Just order mine from keith craft racing
Windsor .020 block
cobra forged crank
forged piston
manley rods
assembled and shipped $3000.00
Got this from GP on Corral.net
chosen69
Jan 29, 2015 08:05 PM
46yblock
Jul 24, 2010 06:41 PM
eurosurplus
Jan 15, 2010 04:21 AM
