460 carb milage?
Old Feb 27, 2003 | 11:24 PM
elliott's Avatar
elliott
Question 460 carb milage?
Does anyone have a MPG figure for a 79 F250 crewcab with 460/4.10/31.7" tires? Tac's 2825 @ 65 MPH
This is a stock engine, other than carb. It has an Edelbrock 750 CFM with electric choke. Other than maybe changing carb's, I don't want to get into the engine at this time.
My son took it back to Ft. Bragg (1400 miles) and ran about 8 MPG. I have thought about adding an overdrive unit (not transmission) which would get the axle ratio up around 3.00.
That would give about 2050 RPM @ 65 MPH.
Any input would be appreciated.
Old Feb 27, 2003 | 11:39 PM
carpe_diem's Avatar
carpe_diem
460 carb milage?
I don't have first hand experience with 70's carb. 460s but from what I hear from those who do, they get less than EFI 460 engines, with the latter getting 11MPG, 12 max. So 9 , 10 mpg seems to be about right. 8 mpg is not way off.
My son took it back to Ft. Bragg (1400 miles) and ran about 8 MPG. I have thought about adding an overdrive unit (not transmission) which would get the axle ratio up around 3.00.That would give about 2050 RPM @ 65 MPH.
Interesting... how much would this cost? I too get almost 3,000 at 65mph.
Old Mar 11, 2003 | 05:03 PM
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd
460 carb milage?
I don't normally need to take it over 55 MPH. I have 5.13 gears.
I am easy on the pedal.
I am planning on changing to 3.54s to have my RPMs down at 70MPH. I am running 31.7 tall tires now am thinking of going to 35" tires.
Greg
Old Mar 17, 2003 | 12:47 PM
Aggie 460's Avatar
Aggie 460
460 carb milage?
I just drove about three hours on the highway and I got 12 mpg. My truck is a '85 f250 with a 460 and i just put a q-jet on it, but i was getting about 11 before the q-jet. No smog stuff either, 3.73 gears and 32" tires cruising at 70-75 mph.
Old Mar 25, 2003 | 05:45 PM
morningtown's Avatar
morningtown
460 carb milage?
I own a '78 F250. I changed the axle ratio from 3.55 to 4.10 to pull a large trailer and the mileage dropped from 11.5 to 8 mpg so it sounds like your truck is running OK. Based on my experience an overdrive is bound to help, although you can buy an awful lot of gas for the price of an OD!
Old Mar 25, 2003 | 06:09 PM
idahocrewcab's Avatar
idahocrewcab
460 carb milage?
I've got a 77 F-250 Crew 4x4 with a carb'ed 460. It gets 8mpg. Same gearing, but 33" tires. From my experience, I would say your mileage is about right.
Old Mar 27, 2003 | 10:54 PM
LxMan1's Avatar
LxMan1
460 carb milage?
Yeah, my 77 F150 460/C6 3.00 gear gets between 6&8. And I'm only turning 2200rpm@70 mph. That's with a 32" tire. I need about a 3.70 gear for sure! My Windstar turns more rpm than that and it has overdrive!!!!
Jimmy
