Castrol Tection?
Old Nov 18, 2010 | 12:45 AM
Major Marvin's Avatar
Major Marvin
Castrol Tection?
Anybody try this oil? Right after I bought my truck, I went over to Pep Boys so I could get ready for the quickly upcoming 5000 mile maintenance. I bought four gallons of this Castrol stuff, just tonight I read at the bottom of the label on the back that it's BP... Doh.
Soon after that shopping trip I went to Wally World and see that synthetic Rotella was even less money than this Castrol Heavy Duty Dino oil. That got me a bit bummed because I kind of like Pep Boys.
Right at the moment I am running Delo 15W40. I'm just looking ahead and want to do the right thing by my truck and my wallet, even though I'd like to run Redline, Royal Purple, or maybe even Amsoil but that doesn't seem reasonable because of the short maintenance intervals on our 7.3's.
One more thing, I live near Santa Fe, NM and it sometimes gets down to 5 degrees Fahrenheit.
Castrol Oil Info:
Tection Extra 15W-40
Protection for latest technology US trucks & equipment
Applications
Castrol Tection Extra is a 15W40 heavy duty diesel engine oil designed to provide superior performance and protection for the latest technology US 2007 compliant EGR engines, including those equipped with Diesel Particulate Filter exhaust after-treatment devices. Its primary application is for US trucks, buses and equipment, including both EGR and non-EGR engines.
Features / Benefits
Castrol Tection Extra’s special low ash formulation has been developed to provide excellent performance and protection for diesel engines.
Tection Extra’s benefits include: • Improved soot management and low ash technology to reduce soot related oil thickening
and engine wear. • Improved sludge protection to fight sludge formation and maintain a clean engine. • Outstanding cold pumpability to protect engines during start-up in cold weather. • Advanced oxidation control to counter sludge build up and increase oil life.
Specifications / Performance
• SAE 15W40 • API CJ-4, CI-4 PLUS, CI-4, CH-4, CG-4, CF, SM • Caterpillar ECF-3, ECF-2, ECF-1-a • Cummins CES 20081 • Mack EO-O Premium Plus • Volvo VDS-4 • Detroit Diesel Power Guard 93K218
Storage
All packages should be stored under cover. Where outside storage is unavoidable drums should be laid horizontally to avoid the possible ingress of water and the obliteration of drum markings. Products should not be stored above 60°C, exposed to hot sun or freezing conditions.
Form No. 1855 Rev. 2/4/2010 (over)
Health, Safety and Environment
Health, safety and environmental information is provided for this product in the Materials Safety Data Sheet. This gives details of potential hazards, precautions and First Aid measures, together with environmental effects and disposal of used products.
Castrol International will not accept liability if the product is used other than in the manner or with the precautions or for the purpose/s specified. Before the product is used other than as directed, advice should be obtained from the local Castrol office.
Typical Characteristics
Test Method Units Value
SAE 15W-40
The above figures are typical of those obtained with normal production tolerance and do not constitute a specification.
This Data Sheet and information it contains is considered to be accurate at the date of printing. No warranty or representation, expressed or implied, is made as to the accuracy or completeness of the data and information contained in this publication.
It is the User's obligation to evaluate and use products safely and within the scope advised in the data sheet and to comply with all applicable laws and regulations. No statement made in this publication shall be construed as a permission, recommendation or authorization given or implied to practice any patented invention without a valid license.
The Seller shall not be responsible for any loss or damage resulting from any hazards or risks identified in the data sheet and which are associated with petroleum products concerned (provided that this disclaimer shall not affect any statutory rights of the Buyer of the petroleum products concerned).
Test
Method(s)
Unit
Typical
Flash Point, COC
ASTM D92
°C
232
Viscosity, Kinematic 100C
ASTM D445
mm2/s
15.2
Viscosity, Kinematic 40C
ASTM D445
mm2/s
114.0
Viscosity Index
ASTM D2270
None
139
Viscosity, CCS -20C (15W)
ASTM D5293
cP
6800
Ash, Sulphated
ASTM D874
% wt
0.97
Total Base Number, TBN
ASTM D2896
mg KOH/g
Pour Point
ASTM D97
°C
-42
Old Nov 18, 2010 | 09:32 AM
Talyn's Avatar
Talyn
Amsoil is cheap.
Old Nov 18, 2010 | 09:42 AM
Major Marvin
Originally Posted by Talyn
Amsoil is cheap.
Cheap but good or cheap but bad?
Old Nov 19, 2010 | 12:34 AM
XBAJBUSX's Avatar
XBAJBUSX
Amsoil not cheap price wise but good oil
Old Nov 19, 2010 | 02:47 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
return it and get the synthetic or just run what you baught, the oil you have is no big deal providing its rated for diesil, your good. Least its not reclaimed engine oil.
Old Nov 19, 2010 | 03:25 AM
ford390gashog's Avatar
ford390gashog
Well the castrol runs about 9.99 on sale and meets all the specs for your engine rotella is about 20.00 at walmart. So if you payed 20.00 for castrol return it.
Old Nov 19, 2010 | 09:25 AM
Major Marvin
Copy that, thanks ya'll
Gettysburg150
27
Jan 15, 2015 09:18 AM
parkland
General Diesel Discussion
Mar 31, 2014 06:06 PM
zillah
Oil & Lubrication
Jan 23, 2009 09:17 PM
Berol
Modular V10 (6.8l)
46
Jan 13, 2004 08:01 PM
