pulling crank pulley
Old Nov 17, 2010 | 08:54 PM
410F-100's Avatar
410F-100
Aight so the book I have on the FE aint worth wiping my *** with!!!
whats the best way to unbolt the crank pulley so I can put a puller on it and get to my timing chain..
I figure I could put the truck in gear and block the wheels, but I need to keep the engine at TDC to do the timing chain and to put everything back togather...
I was a little kid the last time I got to do a timing chain and dont rember much, and since then most of my experience has come from small VW engines.
Any good sugestions?
Old Nov 17, 2010 | 08:59 PM
ford390gashog's Avatar
ford390gashog
Just unbolt it it does not matter if you move the crank when doing a timing chain as you will have to realign the cam to crank anyway. Just make sure when reinstalling it both dots on the timing gears are pointing dead on at each other.
Old Nov 17, 2010 | 09:17 PM
410F-100's Avatar
410F-100
Right right, I rember the dots, or in this case arrows... I just couldent rember the whole TDC part!
thanks mann
Old Nov 17, 2010 | 10:39 PM
Redmanbob's Avatar
Redmanbob
Uhmm err ahh
What book did you "obtain"? Not sure of an FE manual lacking "legible data on this subject". Not sure of the year you plan on tyinkering with but be aware, "as stated in all the books that come to mind" the timing set is with or without a C washer. Newer sets have the spacing built into the gear. If you install a later gear set with older parts you chance a cam/lifter alignment issue that will result in havoc.
Pulley removal = 4 bolts and main bolt. Then puller for pulley, then crank spacer. Then cover and splash tin ?
Old Nov 18, 2010 | 07:51 AM
410F-100's Avatar
410F-100
I have a Haynes book... Iv just found that it is rather bleak, and could be a little more indepth with things... But it did get me through doin a head job int the truck!!!
The engine is a 74 360 with a 428 crank in it of unknown year, and I dunno what cam was used when the motor was built.
the timing chain I bought is the Edlebrock performer link, 7808.
Old Nov 18, 2010 | 09:14 PM
410F-100's Avatar
410F-100
Soo I guess I should ask, Did I order the wrong timing chain? or will I need to wait till after I pull my timing cover to know for shure???
Old Nov 18, 2010 | 09:38 PM
Bear 45/70's Avatar
Bear 45/70
You should have gotten a timing set for a pre-1972 FE engine (352, 360, 390, 406, 410, 427 or 428). That way the cam will be timed straight up and not 4° retarded to make the emission nazies happy. It does not matter what crank is in what FE block, the chain will fit.
Old Nov 18, 2010 | 10:32 PM
410F-100's Avatar
410F-100
Lmfao No emission nazies hear in wyoming!!!
So dose it matter what cam I have (early or late model) if this timing chain will work ok or not???
Just curious what are the advantages or dis advantages would 4* retarded have over straight up timing???
Old Nov 18, 2010 | 10:47 PM
Bear 45/70's Avatar
Bear 45/70
The feds mandated the 4° retard so all timing sets for the 1972 and later engines had it. Any FE timing set DOES NOT care what crank or cam you have. It supposedly improved NOX emissions at the expense of power and mpg.
Old Nov 18, 2010 | 11:29 PM
410F-100's Avatar
410F-100
huh, that sucks... well I guess Ill know better next time huh!!!
Old Nov 18, 2010 | 11:38 PM
ford390gashog
BEAR made a good point about the 4 degree gears. What part number did you use from Edlebrock?
Old Nov 18, 2010 | 11:43 PM
ford390gashog
The 7808 according to edlebrock is at 0 degree stock and can be advanced or retarded up to 4 degrees at the keyway.
Old Nov 18, 2010 | 11:47 PM
410F-100's Avatar
410F-100
Yah I just found the Installation instructions hiding in the box!!! Sorry I tend to forget to look for small things like that!
Ok so I allredy know that I wont install it at 4* retarded...
Any advantages of 4* advanced?? That would give me more low RPM torque right? what would be better for gasmilage straight up? or 4* advanced???
Old Nov 18, 2010 | 11:49 PM
410F-100's Avatar
410F-100
can I even run advanced timing with a stock cam???
30
May 22, 2026 10:18 PM
dionysius
Nov 22, 2016 01:30 PM
Mikerage
1997 - 2003 F150
30
Jul 29, 2016 02:59 PM
DBGrif91
Sep 15, 2013 12:55 PM
tom87
Feb 9, 2001 09:05 AM
