Busted Shock Mount
Old Nov 17, 2010 | 08:27 PM
jmshaver13's Avatar
jmshaver13
Busted Shock Mount
I have busted the rear shock mount on the rear passenger side of my truck. What is a good way to replace this or something I can put in place of the shock for the same support? I have a 1972 F-100 truck.
Old Nov 17, 2010 | 08:51 PM
Encho's Avatar
Encho
The Southernmost Mod
Try searching the sections of the forum and posting this question in the appropiated era section for your truck, you'll get a lot more useful answers there... And welcome to FTE!.
Proper section for your truck:
1967 - 1972 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Now go post there your question, good luck!.
Old Nov 17, 2010 | 08:55 PM
ford390gashog's Avatar
ford390gashog
A MOD will move this to the correct forum for you just remember from now on to use the correct section for your problem. Is it the upper or lower shock mount? Also FYI the shock does not support any weight.
Old Nov 18, 2010 | 04:05 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2009 F150 forum.
Welcome and thanks for joining us at FTE!
