E4OD Speedometer Cable
Old Nov 17, 2010 | 08:11 PM
danlee's Avatar
danlee
I put an 2WD E4OD in an '83 F100. The trans has a VSS in the tailshaft with a gear. My Speedometer Cable has a plug that goes into the tailshaft where the VSS is installed.
I need a Speedometer Cable that will fit my Head Unit, and plug into the VSS.
I looked on LMC truck and found this cable:
47-2027 SPEEDOMETER CABLE 1 REQ
I don't know if this cable has the right ends for my application.
Old Nov 18, 2010 | 02:53 PM
Lazy K's Avatar
Lazy K
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4 Have read through this link. I think these guys should have something to do your job.
Old Nov 18, 2010 | 08:17 PM
danlee's Avatar
danlee
I picked one up at Advance Auto Parts today. It looks like it will do the job. I asked for one for a '91 F250 4WD Diesel. The transmission end looks right. I will have to try the head end, when I get back to the truck to install it, but that looks OK also.
If that doesn't work out, I'll return it and contact the people at your link. Thanks for posting that. It's good information.
Old Nov 19, 2010 | 08:17 AM
Lazy K's Avatar
Lazy K
Good man. I hope what you got solves your problem.
Rentaro
Feb 18, 2016 03:15 AM
forkandbowl
Aug 7, 2015 07:09 AM
dotcentral
Aug 18, 2014 11:24 AM
4tl8ford
Mar 7, 2014 09:48 PM
