Boost hoses
Old Nov 17, 2010 | 02:44 PM
Ringwood1's Avatar
Ringwood1
Boost hoses
Hi,
I have a 2004 F250, 6.0 with just under 100K. I noticed that the turbo hoses are covered with thick dried oil. It's not wet, but feels greasy. It's covering the blue hose and a few inches on the metal pipe. The clamps seemed tight, but I could get a turn on each one without over tightening them.
The hose on the lower left under the battery is the same. Completly covered.
Does anyone know what causes this?
Thanks
P.S. I also took out the EGR to clean it. It was mostly dry carbon and a little greasy on the bottom of the valve. It cleaned up nicely and moved freely.
I was set to add pictures, but I couldn't find the 'Manage Attachments' button. In the posting rules it says "You may not post attachments"
Old Nov 17, 2010 | 02:49 PM
bpounds's Avatar
bpounds
The oil comes from crankcase ventilation, which is dumped into the turbo intake. The oily fumes slowly build up in the boost plumbing. Not a big deal, but it does eventually weaken the boots.
You can't post attachments yet. But you can store photos on free sites like photobucket and then include href links in your post so the photos will display. That's how most of us do it, even though we could upload attachments if we wanted. It's too much hassle to manage them on this site.
Welcome. (well, you're not exactly a new guy)
Old Nov 17, 2010 | 03:25 PM
lawnboy1965's Avatar
lawnboy1965
A CCV re-route will cure that problem. Just do a search. Its cheap and easy.
Old Nov 17, 2010 | 05:10 PM
High Binder's Avatar
High Binder
I host my pics at tinypic.com
Old Nov 17, 2010 | 05:14 PM
69cj's Avatar
69cj
If the boost hoses can weep oil they can also leak boost press. I would and have replaced them for that.
