overfill leak
Old Nov 17, 2010 | 10:05 AM
79bigblock's Avatar
79bigblock
overfill leak
so i need an answer my 79' f150 leaks antifreeze out of the radiator overfill... is it the cap maybe not holding pressure??
Old Nov 17, 2010 | 02:37 PM
steponit's Avatar
steponit
Make sure you fill it no higher than 1" below the sealing ring of the rad cap
Lots of people make the mistake of overfilling the rad
Old Nov 17, 2010 | 03:36 PM
jim collins's Avatar
jim collins
I would guess bad cap or overfill as mentioned. You could add in a coolent recovery tank, fill the radiator all the way up and add a little in the recovery tank. Overflow goes in the tank, then is pulled back in as it cools down. Keeps air out of the system .
Old Nov 18, 2010 | 10:09 AM
79bigblock's Avatar
79bigblock
thanks Jim Collins i went o reilleys yesterday and got a Murray 16 psi cap and it is working great.
Old Nov 18, 2010 | 05:35 PM
jim collins
I don't know how much psi the radiator will handle, but you want to remember you have a heater core under pressure too, so don't overdo it with the psi. I found that out a few years ago with a new radiator and a old heater core. I put a cap on that had more psi than what was recomended for the vehical . You can guess what happend, blew the heater core and hot water in the floor all at once, not fun.
Old Nov 18, 2010 | 08:00 PM
79bigblock's Avatar
79bigblock
hey jim im dumbfounded with this one. but i bought 35/15.50/15 swampers for my 1979 f150 will they fit on a regular batman rim or eagle alloy bullet hole rim? or will they rub the coils ?
Old Nov 19, 2010 | 07:42 AM
jim collins
Sorry i can't help on that but somebody will see it a tell you. JIM
