Overdrive Ratios
Old Nov 17, 2010 | 07:46 AM
95 F150 Dude's Avatar
95 F150 Dude
Overdrive Ratios
Guys,
I'm doing a little research in determining the final (overdrive or 5th gear)drive ratio with the AOD, E4OD and ZF's. Any clue?
Thanks, Scott
Old Nov 17, 2010 | 09:22 AM
Conanski's Avatar
Conanski
That would be 0.67 for the AOD, 0.71 for the E4OD, 0.77 for the close ratio ZF, and 0.76 in the wide ratio version.
http://www.vibratesoftware.com/html_...sions_Main.htm
Old Nov 17, 2010 | 09:26 AM
95 F150 Dude
Conanski,
I'm impressed, you are just a walking encyclopedia when it comes to Ford light duty truck information. Thanks and have a great Thanksgiving
Scott
Old Nov 17, 2010 | 11:05 AM
Conanski's Avatar
Conanski
Don't thank me thank the Interweb.. it's a treasure trove of usefull information.. when that info is correct.. which it appears to be in this case using other sources as reference.
