Sponsored by: Auxito
Burning up starters
Old Nov 17, 2010 | 06:53 AM
garye5007's Avatar
garye5007
Trailering
Burning up starters
Hi, I have a 2000 f-150 6 cyl and i'm on my 3rd starter... starts once and then just clicks brought back and they said the starter is no good (burned up)?
Is there anything that could cause me to keep ruining starters? any help would be greatly appreciated! Thanks, Gary
Old Nov 17, 2010 | 08:38 AM
thomabb's Avatar
thomabb
Oil from a leak will destroy the starter. Also if your solenoid is sticking and sending power to the starter while the truck is running, it will overheat it and burn it up.
Old Nov 17, 2010 | 09:56 AM
garye5007's Avatar
garye5007
Trailering
Thanks for the reply! I'll check that out
Old Nov 17, 2010 | 12:00 PM
Bluegrass 7's Avatar
Bluegrass 7
Insist they test a replacment before you leave the store or go to another vendor.
One start does not burn up a starter.
You could hear anything going on that is not a normal sound when starting the first time.
Is it the correct part for the application?
Look at the flywheel for signs of contact with the side of the wheel anyplace but the teeth and for any broken teeth..
If there is side contact, the starter needs a shim to space it out far enough to clear but should not have to be done.
Good luck.
ZombieJames
1997 - 2003 F150
Aug 16, 2016 12:11 AM
jerome6692
3.8 & 4.2L V6
Dec 7, 2015 08:22 PM
adamkat22
51
Sep 4, 2015 07:53 AM
pwdiesel
May 1, 2011 06:57 PM
