6.9 glow plug problem
Old Feb 27, 2003 | 07:40 PM
BRUCE_M_73651's Avatar
BRUCE_M_73651
Hey guys, have a 1987 F250 diesel, 4WD, 360,000 miles, yep thats right 360,000 miles. Latley a problem with starting, , glow plugs not staying on long enough to start in cold weather. Pulled glow plugs all had contintunity, checked each plug wire, all were getting current, replaced relay,, no change, replaced water temp switch which is in the wiring loop for the glow plugs,, no change. Any more suggestions?
Old Feb 27, 2003 | 09:40 PM
mhalter's Avatar
mhalter
Ya might try posting this in the Diesel Forum. You'll probally have better luck there.
Welcome.
Old Feb 27, 2003 | 10:37 PM
BRUCE_M_73651
Thanks!!
Old Feb 27, 2003 | 11:28 PM
eckart's Avatar
eckart
check the battery voltage. It can cause to long of a glow time and kill your plugs and can also cause to short of a glow time. Clean the heck out of all conections and grounds. I had a 6.9 that was bullet proof but the glow system had a lot to be desired. good luck.
Old Feb 28, 2003 | 05:49 PM
Doug97058's Avatar
Doug97058
Check the GLOW PLUG TIMER---just replaced one on a 1989 6.9 after replacing 6 or the 8 glow plugs.
Timer should cycle for 30-45 seconds
Doug
Old Feb 28, 2003 | 05:54 PM
BRUCE_M_73651
Is'nt the timer part of the relay block that controls the glow plugs?
