Distributor with limited rotation.
Old Nov 15, 2010 | 05:48 PM
1977F1504X4AUBURN's Avatar
1977F1504X4AUBURN
So, I've got a 1977 F150 4x4 with a 351M/400 engine. Stock ignition system. I'm trying to advance the timing (turning the distributor clockwise) but it rotates a little and then stops and wont turn any further. I can retard it until the engine wants to die but it just wont advance as far as I would like. I have had the truck for about 2 months. It sounds like it may have a cam in it by the sound of it but I'm not taking things apart right now to find out. Any suggestions?
Old Nov 15, 2010 | 06:26 PM
jim collins's Avatar
jim collins
Is it bumping against something on the engine,like the thermostate housing ? If so,lift up and reset it back ,counter clock wise, one gear tooth. Don't go to far or you will have the same problem the other way.
Old Nov 15, 2010 | 09:34 PM
joerickson's Avatar
joerickson
almost sounds like you may be a tooth off it it can retard by not advance
Old Nov 15, 2010 | 09:49 PM
fairlane68's Avatar
fairlane68
No...I doubt it's either of those. I mean, it can happen, quite frequently in fact, but I don't think that's the case here. I think what's going on is that the base of the distributor is partially seized by coked (varnished) oil. The best remedy I know of is to try to remove the distributor, but use WD-40 or lightweight motor oil liberally, and move it back and forth in small increments. "Delicate" is a word that comes to mind...
And trust me...there is a cam in there.
Old Nov 16, 2010 | 09:18 AM
jim collins
You could be right, but thats the reason i ask him if he could see it bumping against the thermostat housing. If he could then that may be the problem. I just never made it real clear as to what i was asking him i guess. yeah ,i think he will find a cam too ,if not ,that will be interesting.
Old Nov 16, 2010 | 09:56 AM
Nathan Plemons's Avatar
Nathan Plemons
Mine was very tight when trying to move it. It eventually gave but after sitting for as long as it had, I wasn't surprised it was tight.
Old Nov 16, 2010 | 10:07 AM
1977F1504X4AUBURN
I will check it out tonight. It could be as simple as the vacuum advance hitting the thermostat housing. If it is a "tooth off", how does that happen? Is the distributor installed when the engine is at TDC? I think the timing line on the balancer is also off. I have to retard the engine until it dies before coming within 30 degrees of where it needs to be. Do you think this and the distributor are related issues?
Old Nov 17, 2010 | 01:49 PM
1977F1504X4AUBURN
So ... the distributer is not hitting anything on it's rotation ...
Old Nov 17, 2010 | 03:45 PM
jim collins
Well i'm at lose now if its not hitting anything. Just a wild guess,could the timing chain be off one tooth ?
