1988 F350 Fuel Injected 7.5 liter. No spark and seemingly no fuel rail pressure.
No spark and seemingly no fuel pressure.
Truck was running fine when I parked it yesterday. This morning it wont start. After checking for spark by pulling a wire off the dist. and incerting a screw driver, and then rolling the engine over, (no spark). Also found very little, if any, pressure in the fuel line at the injecters.
Any ideas??
Thanks for any advice given.
Any ideas??
Somewhat revised..
I do have some fuel pressure. Each time I dump the pressure at the pressure release valve on the fuel rail, then turn my ingnition on I get pressure in the fuel rail again. I'm not sure its enough to start the engine but I would think so. I also have eletrical power at the ignition coil (small wires) while the ignition switch is on. But while turning the engine over I dont get spark from the coil wire at the dist.
Does the fuel pumps run all the time the key is on or does it run for one second and stop?
You have three possible reasons for no spark.
1. Bad computer, unplug to check if spark returns.
2. Bad TFI module on the side of the distributor, take to auto parts store to check if good or not.
3. Bad PIP sensor in the distributor, if on spark with computer unplugged and good tested TFI module replace distributor or stator inside of it.
Hey thanks a ton for your responce. I sure need help with this one because I'm old school,, way old school,, and still favor a carb and a dist with points.
As far as the fuel pump/s,, I have dual tanks and as close as I can tell no matter which tank the tank switch is turned to the fuel pump only runs a second or so once the key is turn to ON.
I'm pretty sure I basically know which parts your refering to other than the "computer".. Where do I find the computer on my 88 F350?? What does it look like?
My Chilton doesnt mention one so I looked over the suggested replacement parts on Auto Zone web site for my ignition system but a computer isnt listed. So if you can point me in the right direction I'd be way greatful!
Like Subford mentioned, remove the TFI module at the base of the dist & have it tested.
The module will have 2 screws recessed in the holes of the module. Any parts store will have the tool you need to remove the screws. Remove the connector & the 2 screws & pull down on the module. Have it tested.
If you replace it be sure to smear the grease that comes with it on the face of the module where it contacts the dist..
yep just got through with this ordeal myself. sounds like tfi module as already stated. i can add you may have to loosen and turn the distributor some to have access to the screw. once on 302 i had to lift the distributor up to get at them cause the tfi module was hitting a air condition support bar.
Yeah I bet you will miss her. I had a Boston Terrier for 12 years. She died some 15 years ago and I still miss her when I see another one that looks like she did.. Yep, they get under the skin..
Ok I unpluged the computer, still no spark at dist. I had the TFI check out, apparently its OK. So I bought a dist and will install it sometime later today. Sure hope that does the trick cause I already miss driving my old Ford.
Subford; Well I did all you have suggested including installing a new dist but still no spark. Have anymore suggestions?? And thanks for your help
Larrylass; Theres alot of info there and sure to be handy as far as fuel problems.. But as I understand it as long as I'm not getting spark my fuel system wont build high pressure. But what do I know, could be way off base.. Thanks for pointing out that info..
Thanks for the replies guys.
I do have power at the coil on both sides of the plug when the key is on. I'll have to check once I have day lite as to whether I still have power there while I'm cranking the engine. I'll check the coil wire too and report my findings.
With 125,000 miles on me old ferd (I bought it second hand 5 years ago) it wouldnt surprise me if that coil has never been changed.
Btw, what is the name of the grease used on eletrical connecters/connection?
