turn signal switch replacement?
Old Nov 15, 2010 | 08:45 PM
charleswood6969's Avatar
charleswood6969
I was gonna suggest a very low-cut blouse, a set of Daisy-Duke cutoff's, and selecting one of your boyfriends guy friends who has mechanical ability to flirt with. I seems to work with me when wommenz need something fixed.
Old Nov 15, 2010 | 10:28 PM
rodneywar's Avatar
rodneywar
Originally Posted by bubblegum
But but, it's cold out!!! Not to mention people are stupid and don't know better and will think I'm following rodneywar's suggestion and giving them the finger
I'm about to cut the side oh his head open when he gets back (whenever that is), as he doesn't even answer his phone - to heck with deer (or whatever else they are out hunting), I'm more important than some wild animals dammit!!!
Did your mother not teach you that if you are to ignore a girl's bitching and whining and carrying on anyways, you should at least do so in a less-blatantly-obvious way? People these days, no manners at all!
i love to give ppl the finger i will roll down the window in a blizzard to give someone the finger!! i think it gives more of a punch if you do it outside the cab
Old Nov 16, 2010 | 03:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
by the time he gets done fabricating a mount, putting the freightshaker switch in will be more work than just replacing the stock switch. and then you are gonna have this BIG ugly thing hanging off the side of the column
Old Nov 16, 2010 | 09:29 AM
bubblegum's Avatar
bubblegum
Tehe, bikini-tops and cut-off jeans on a good-looking girl, every guy's dream, right? But in my case there is no need for this, when in a bind I can always go and see the neighbors (like I did yesterday) - the guy is a big-rig mechanic and has his own trucks too, and for some reason his wife has pretty much addopted me as her daughter - why is that I have no idea, I would definitely never adopt a basketcase nutjob like myself, but hey, they are nice people and I like them, so it all works out in the end.
It is not that big, and not ugly either - I will have it painted matte black to match the steering column, I think it can be made to look nice. My main concern with factory-replacement switches is that unless I go to the dealership and buy an OEM switch ($$$) I do not know how long an aftermarket switch will last - the person at the parts store said they have small wires on them, just like those I saw on that repair cam-thing I was fighting on Sunday. My truck has towing setup from the factory so it needs big wires in the switch - I read on the other diesel site that someone had their factory-style replacement turn-signal switch catch on fire inside his column, I most certainly do not want that to happen to me... Besides the neighbor assured me this will be a plug-in installation, and if I do not like it we can always unplug it and I can buy a factory-style switch and he will put it in for me But the information you provided on the first page of this thread has not been in vain, as I will use it to remove the old switch and part of its harness while still retaining the cruise-control wires - unfortunately this means I may indeed have to fight those pins in the electrical connector, which is majorly annoying!
All this said, can anyone please tell me where in my truck I can find the flasher for the emergency 4-ways? It is not in the fuse panel, that one is for the normal turn-signals, with the 4-ways on I can hear something clicking on the passenger-side of the dash maybe but I have not been able to locate it
Old Nov 16, 2010 | 03:45 PM
tecgod13's Avatar
tecgod13
I don't know if its the same on yours, but I think on my 88 the 4-way flasher is on the backside of the fuse panel?? Like the same spot as the regular, but flip it over? Thats just off the top of my head so I might be wrong.
As far as small wires burning out because of towing, you can always put the signals on relays just like people do for headlights. They actually have nicely made modules that plug into the trailer wiring for just that purpose. I put one in my ranger after the stock flasher had issues with my trailer and it worked great, so I swapped it to my F250 when I bought it.
Old Nov 16, 2010 | 04:17 PM
tjc transport
i ain't rite
Originally Posted by tecgod13
I don't know if its the same on yours, but I think on my 88 the 4-way flasher is on the backside of the fuse panel?? Like the same spot as the regular, but flip it over? Thats just off the top of my head so I might be wrong..
correct. the 4 way flasher is directly behind the blinker flasher on the back of the fuse panel. you need to be a contortionist or a itty bitty mini midget to get behind the dash to get to it.
or you can unbolt the fuse box and flip it over.
Old Nov 17, 2010 | 01:45 AM
bubblegum's Avatar
bubblegum
Well I just got back from work, and OMG, it lives! Neighbor must have had nothing to do all evening to do it, or he just wants his truck back real badly, but either way he fixed it good - Freightliner switch is on the column and working great, and actually does not look out of place at all - not sure how he has it attached there, but there is no giant hose-clamp-like thing around it like some older tractor-trailers have them.
Mine is not there, there's nothing up there at all, even the holes where it would plug in if it were there are empty!
Interesting, and where do you find this thing? Also how exactly does it install?
Well master Tom, I am definitely not a midget, so I guess that makes me a contortionist, for I was able to reach up there just fine while hanging upside down from the seat - however, no flasher there, just empty holes. Actually the only reason I'm asking about it is because my neighbor wanted to know this, but seeing how he has everything installed and working he must have found it somewhere - I will ask him tomorrow if he ever located it.
Old Nov 17, 2010 | 07:26 AM
tjc transport
i ain't rite
i really don't know it if is there or not, i was just going by what the factory service manual says. i never had to replace one on any of my trucks
Old Nov 17, 2010 | 10:44 AM
bubblegum's Avatar
bubblegum
The 4-way flasher-thing in my truck was all the way in the right corner of the dash, he had to pull the glove box to get to it. Maybe part of the factory towing equipment? He says he also found a big relay in that area, hiding behind the plastic panel, any idea what that maybe for?
Old Nov 17, 2010 | 11:56 AM
ttexastim's Avatar
ttexastim
Hope that freightliner switch is a good one. 6 months ago I replaced my turn signal switch assembly with the OEM equivalent that I bought at O'reilly's. The damn plastic must be made in china, cuz 3 weeks ago, my right signal stoped cancelling automatically.
<insert "they just don't make them like they used to" rant here>
Old Nov 17, 2010 | 12:07 PM
rodneywar's Avatar
rodneywar
we need pics please!!!
Old Nov 19, 2010 | 02:35 AM
bubblegum's Avatar
bubblegum
See, this is just what I was afraid of - if there was no other way I would have been forced to buy the genuine Ford as I cannot be asking my neighbor to fix the same problem over and over again, and I most definitely cannot afford any tickets. Thankfully, the Freightliner switch is very very heavy-duty, it has some very big sliding things inside it that make the switching happen, also springs that keep it from flopping around internally. It is a genuine switch from an old truck, US-made and all.
Yes, I will take some for you, but right now I'm tired and cranky and have no idea where my camera is, so maybe tomorrow during daylight, if I do not sleep trough the entire day...
Old Nov 19, 2010 | 06:45 AM
  #28
charleswood6969
I think rodneywar was talking about you instead of the truck....LOL
Old Nov 19, 2010 | 10:39 AM
  #29
ttexastim's Avatar
ttexastim
Sounds good. I'd like to see a pic. I don't want to replace it again, only to have it fail again. I broke my steering wheel puller last time I did it (damn cheapo harbor frieght tools).
Old Nov 19, 2010 | 10:52 AM
  #30
87crewdually's Avatar
87crewdually
also as you have ur hand out the window it is easier to give ppl the finger if they honk at you
It doesn't happen often but you made me laugh out loud, twice.
