Blowing fuses!
Old Nov 14, 2010 | 02:59 PM
brad7.3's Avatar
brad7.3
Blowing fuses!
Hey guys, let me run this past you. My truck keeps blowing the instrument illumination fuse within 1-2 days of changing it. I'm not exactly electrically savvy, and I'd appreciate any suggestions on where to start.
Old Nov 14, 2010 | 03:23 PM
mq1shooter's Avatar
mq1shooter
what # fuse location and verify what fuse rating has been blowing...
Old Nov 14, 2010 | 07:02 PM
brad7.3's Avatar
brad7.3
I think it's position 10, and it's a 4 amp fuse. It's the instrument illumination fuse. I'll change it, and it may blow right away, or it may be ok for a few days.
Old Nov 14, 2010 | 08:24 PM
makomark's Avatar
makomark
Have you added anything to that circuit - gauge lights?
Obviously, something is drawing enough current to pop the fuse; the trick is finding it in a short period of time.
if you added to the circuit, check the addition(s) first. Also check where the wire(s) were routed. Anytime a wire passes next to sheet metal, especially at the edge, you have a potential problem. Sometimes, just cinching up a ty-wrap over the wrong spot will give you fits.
Old Nov 14, 2010 | 09:52 PM
brad7.3's Avatar
brad7.3
I did have gauge lights wired into it, and I thought the same thing, but after I removed them, it's still doing the same thing. Now it's just the stock setup/wiring.
Old Nov 14, 2010 | 11:39 PM
mongo12's Avatar
mongo12
check the grounds for the gauge lights and make sure that you dont have any chaffing wires that are causing a short.
Old Nov 15, 2010 | 06:04 AM
brad7.3's Avatar
brad7.3
The gauges are disconnected from fuse panel.
Old Nov 15, 2010 | 11:58 AM
makomark's Avatar
makomark
I checked the factory diagram. There isn't much downstream of the fuse. specifically, all the lights tied to the dimmer. Instrument panel, ashtray, Shift on the fly (if equipped), heater control panel and radio are all that are shown on that circuit (for an F-series).
From the fuse, it looks like a light blue/red tracer wire goes to a splice and then the same color wires run from the splice to each item listed.
I'd suspect the fastest way of finding your problem is a good visual/physical inspection of the whole circuit. A faster fix may be to just rewire the circuit (in essence, pull a new feed from the fuse to whatever you want to keep illuminated).
Old Nov 15, 2010 | 03:34 PM
brad7.3's Avatar
brad7.3
Hey that's great! It's been doing it since I pulled my radio out a couple weeks ago. I'll start there. Thanks for taking the time to look it up!
Old Nov 15, 2010 | 06:52 PM
makomark's Avatar
makomark
sounds like the logical place to start.
good luck!
Old Nov 15, 2010 | 06:59 PM
ckal704's Avatar
ckal704
Aren't the tail lights in the same circuit as the dash illumination lights? I don't know about Fords, but I was driving our old Dodge Caravan years ago and the dash lights went out. I wondered what the heck that was all about. The cop that pulled me over for having no tail lights told me they were connected so the driver would know that there was a problem with the tail lights.
I am no expert by any means. I am sure someone else can confirm or dispel this theory.
Old Nov 15, 2010 | 10:27 PM
ReFlectiveMan's Avatar
ReFlectiveMan
Check the plugs for the radio, The light for the dimmer was chaffed on mine and making a intermitant contact causing the fuse to blow.
On the F series (at least our generation) the tail-lights are on a differnt circut from the dash lights.
geminijay313
May 23, 2014 11:45 AM
ralleyclimber
Apr 28, 2014 11:30 AM
DATURKEY
Feb 13, 2005 11:38 PM
jayjay4444
Electrical Systems/Wiring
Sep 23, 2004 09:40 PM
