Cracked Block
Old Nov 18, 2010 | 10:40 AM
mabc926's Avatar
mabc926
I'd say patch it the best you can and drive it.
It won't last forever, but you could still get a few good years out of it.
Old Nov 18, 2010 | 10:53 AM
Scratcher's Avatar
Scratcher
Originally Posted by wreckinball
is this thing just a tiny little leak, like a weeping drip or a bunch of drops. It if is tiny, just get that irontite ceramic sealer or the all irontite all weather seal(easier to use, compatible with coolant) and try that before anything else. JB is good but this needs to seal from the inside out and jb cant get in there like an internal sealant. 20 bucks or less bro, give it a try.
When we first discovered the crack it was up on the lift. There was coolant around the heater. The heater was actually loose so we tightened it up and no more coolant loss. The crack is a hairline.
Ive been checking coolant every morning and lost nothing in 5 days.
Old Nov 18, 2010 | 11:17 AM
wreckinball's Avatar
wreckinball
id still seal it somehow, like in my earlier post or something. just my 2c
Old Nov 18, 2010 | 11:22 AM
Scratcher's Avatar
Scratcher
I'll go for the irontite all weather for the inside and maybe some JB for the outer block.
Thanks for the link to their website!
Old Nov 18, 2010 | 11:35 AM
wreckinball
I cant say where you live if they would have it in stores but i am sure it is at most parts stores or truck stores. It is a cheap attempt at sealing things up permanent and it should work great for your issue. Best luck and report back!
BD154
21
Jan 31, 2019 03:22 PM
shizzu
Aug 13, 2017 02:19 PM
Modular V10 (6.8l)
Jan 23, 2017 06:29 PM
comsupany
Dec 27, 2015 05:42 PM
jonathanpatr
Dec 16, 2015 05:56 PM
