Sponsored by: Real Truck
2001 Power Mirrors
Old Nov 13, 2010 | 07:50 AM
auden's Avatar
auden
2001 Power Mirrors
My power mirrors on my 01/F350 are way out of whack. Do not respond correctly to control button in any direction. Any help?
Old Nov 13, 2010 | 09:58 AM
RKern's Avatar
RKern
When mine did this it was the mirror control button. Check fuse first. The first button I bought from local dealer and was not cheap. The second button I bought from edpartsguy much more affordable. If I remember correctly the mirror button is one that can be purchased separately. Edpartsguy is at top of page. The plastic piece that holds the mirror, window, and door lock buttons just lifts off front first easily and carefully. Perform a door panel search or door lock actuators search for some pics. Hope it helps and if it is the button it is easy fix.
Old Nov 22, 2010 | 07:43 AM
auden's Avatar
auden
Power mirrors
Right answer. Less than 30 bucks at Ford and 15 minutes to change. breakdown probably due to rain water! Thanks for help.
Old Nov 22, 2010 | 09:55 AM
RKern's Avatar
RKern
Glad you were able to fix it that easy and it did not break the bank. I never thought about rain until you mentioned it, I had blamed mine on armour all. I do not know if you saw the edpartsguy at the top of the page, but he sells Ford OEM parts just like your local dealer and if you can wait has waaaaaaay better prices.
