Any all-in-one gauges?
I've read on this website about importance of the eot & ect difference. I've also read about the exhaust temp importance. Can anyone tell me if there is a gauge set that does trans temp & before mentioned readings? I do pull a trailer & a fiver & I try to do all the preventive maintenance suggested & treat it very kindly. Thank you all!
Rick, look up Edge Insight with the EGT probe. That might interest you. There are not any that will read fuel pressure and oil pressure. Those would have to be separate gauges.
I use Scanguage II, but it wont read or have access to EGT
Edge Insight with EGT probe is around $360
Scangauge II is around $160
on
The DashDAQ uses a seperate probe, like the EGT probe, to get fuel pressure, but it is all run through the same screen.
Now the DashDAQ with the 3rd part software to get all this stuff done is quite pricey, but it can be done with just the one monitor.
Eventually Edge should be able to offer the same setup with their CTS monitor too.
