Truck Pull Advice!!!!!!
3.08 is an economy gear. Its meant to get you mileage with that OD tranny. Simply put, assuming you both had the same transmission, the guy with a 3.73 gear only needs 200ft-lbs of torque to put the same torque to the ground as the guy with 242ft-lbs and a 3.08 gear. And with a limited sliip or locked rear, he's trying to force each driving tire to put half of that power to the ground. The open diff is pushing all that torque to the ground through the one tire. You can see how this would be bad for towing or a tug-of-war.
-=Whittey=-
[edit] You can get your parts at MotorHaven (who supports this forum), or Summit, or Jegs or whoever.
BTW the aftermarket diff cover with the support screws gives some added strength to the ring and pinion under high towing or pulling loads. I picked my R&P ratio with only one consideration: towing. I am running at almost exactly my torque peak of 2000 RPM at 65 MPH in OD. I've got a ton of extra cooling built into my tranny, with the big gears and running in the fat part of the torque curve it tends to hold in OD rather than downshift, so I can tow in OD with no problem. For zero speed pulling, like you're talking about, the more gear the better. 4.56s would be ideal, but you couldn't affords to drive it.
I've dragged trucks with my 4.9L 3.08 8.8" because I have a Bronco, which has MUCH better weight distribution than any unloaded pickup, AND because I know how to win.
1. To get the odds in your favor, put all the weight you can in your bed - the farther back, the better.
2. Next, shift to the SLOWEST ratio you can get in 2WD, which means if you have a 4WD: put the t-case in 4L and the transmission in 1st, but DON'T lock the front hubs.
3. When you hook the trucks together, make SURE your point of attachment is HIGHER than his. This robs him of any weight HIS rear axle is carrying, and transfers it to YOUR rear wheels.
4. Hook the trucks as CLOSE together as you can, for SEVERAL reasons:
a) if you've managed to hook up higher, a short chain/rope/strap will give you the most benefit;
b) a short chain throws less schrapnel if it breaks;
c) it allows you to double (or more) a long chain so it's less likely to break.
* If you're questioned about why, say it's for safety, but don't tell them about "a".
5. If you're hooking up LOWER than your opponent, you want as MUCH distance between you and him as possible, so he steals less of your traction. (Never mention the real reason WHY you're adjusting the distance - just make up a line about not wanting him throwing rocks at your back window, or something.)
6. Make sure your tires are on the cleanest, flattest, & roughest (gritty, not bumpy) pavement you can find, and try to put his wheels on sand, gravel, oil, water, or lumpy pavement. This minimizes his traction.
7. When you take off, don't try to spin the tires - it's the worst thing you can do. Take off smoothly, keeping engine revs as low as you can without stalling. If you have a manual, try to get the clutch fully released quickly, WITHOUT stalling the engine or chirping the tires. If you have an auto, put it in the lowest gear and leave it there. Even if you start rolling back, follow those guidelines - if he hits a slick spot, you might get him rolling back and kill his engine.
8. Make sure your truck is in good general repair - tires inflated to max pressure so they can take the weight, carb tuned, timing set, air filter clean, trans fluid topped off, brakes working, bumper/hitch bolts tight, etc.
You were looking for a chart. well there you go.
I got this from my truck owners manual
towing capacity for a 4.9 L with different ratio is
Ratio pounds
3.08 0-2100 Lb
3.31 0-2800 Lb
3.55 0-3500 Lb
Of course this is the Chart for a 5 speed overdrive manual transmission.
So like you can see. with 3.08 axle you can't haul that much. I got 3.08 axle ratio in my truck too. and I don't like that. not enouph power. I'm changing the axle for 3.55
If I can give you a really good advise , Don't try to Pull another truck with 3.08 gear ratio. It's probably gonna cost you more in repair. And I garanty that you'll lose the fight. Change axle ratio , then you're in business.
Hope this was helpfull
see ya
If the other trucks have shorter wheelbases than yours you will probably have trouble because they will have more weight over the rear wheels. There's nothing you can do about that, but you could use it as an excuse.
the chevy i wanna hook up to is higher than mine (frame height) looks like i might be at an advantage
Ill probably go after I get my hitch.
My friend will take pics with my little digital camera and i'll post them on my webpage and put up a link.
Anybody else have any advice, tips, safety concerns(truck or human), or good ideas for my Truck-of-war?
You will be turning more revs at a given speed with bigger gears but that's generally necessary for better acceleration, and quite useful for in-town driving. Unless your truck lives on the highway 90% of the time 3.08s have very little to offer.
Lockers and or limited slip differentials have no effect on speed in gears whatsoever, they merely improve traction by splitting the available tractive force between both wheels.
How difficult an install? Depends. From the questions you've been asking, I'm pretty sure you're not an experienced mechanic, but I may be wrong. Regardless of your skill level, it's not a job you should attempt the first time without some experienced guidance. You'll also need a good shop manual, preferably the Ford factory manual, normal hand tools, including a standard torque wrench and a DIAL torque wrench in inch-lb increments, a slide hammer, a dial indicator on a magnetic base, a set of calipers or a 1" micrometer, a variety of tools for installing seals, bearings and side shims, access to a bearing press. It's not a particularly difficult job, just time-consuming.
The important thing about rear end work is that there's no such thing as close enough. It has to be exactly right and you may need to tear it apart several times to get it right.
Neither will a locker or L/S.
If you want to buy something to improve your chances, get a good ClassIII or IV hitch reciever and a long-drop draw bar, but install the draw bar upside-down so it goes UP. That'll raise your point of attachment, giving you an advantage.
