Did I make A mistake?
Old 01-05-2011, 12:13 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Originally Posted by wagonerkl
My book says,"If deck warpage exceeds .003 inches in any 6 inch span, or .006 in total, then the block deck must be machined flat." I would assume this means a gasket can effectively fill up to those variations WITHOUT machining. I am NOT a machinist...I just find it odd/entertaining that you can get so many different "RIGHT" answers when you ask different machinists.
The school should have a machinest's straight edge and feeler gages to check the block and as stated above it is good within those specs for a non race engine.
Old 02-16-2011, 12:53 AM
allwthrrider's Avatar
allwthrrider
allwthrrider is offline
Ok everything is back at the school, block bored .020 over & .004 off the deck upgraded to a xtream energy cam & double roller chain so now just waiting to hear it's done.
Old 02-16-2011, 01:34 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
If the shop teacher is any good at all you are going to be a very happy FordDriver.
Good luck with it and keep us informed.
Old 03-17-2011, 10:57 PM
allwthrrider
Well I picked the motor up today, hopefully have it in and running before to long
Old 04-12-2011, 12:21 AM
allwthrrider
It's on it's way back in,, I tried adding some picture but they won't load, what am I doing wrong?
Old 04-12-2011, 12:37 AM
allwthrrider
Hopefully this works
Old 04-12-2011, 12:41 AM
allwthrrider
Old 04-12-2011, 02:37 AM
jchamp429's Avatar
jchamp429
jchamp429 is offline
Hopefully she runs as good as she looks Keep us posted.
Old 04-12-2011, 08:46 AM
69cj's Avatar
69cj
69cj is offline
You could pick up a few extra ponies by installing a fan clutch or an electric fan on that thing.
Old 04-12-2011, 09:48 AM
allwthrrider
Yea I've been kicking around the thought of a electric fan, & I know it's not original but I think the yellow looks good against the blue
Old 04-12-2011, 10:08 AM
jchamp429's Avatar
jchamp429
I like the yellow tips, nice little reminder to catch your attention every time you bend over the front of it that there's a blender right below you Solid black blends in so well with pavement in low light, I catch myself forgetting all the time. Luckily no painful reminders yet, knock on wood
Old 04-12-2011, 02:08 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I did electric fans on my 2000 Navigator and it looks a lot cleaner, makes less noise, has less stress on the water pump and gives some more horses to drive the truck. I used a set of fans from a V8 Continental that is 2 speed and has the factory guards built in. Total cost with the fan controller from Advance A.P. about $80.00 and 1 hour to install. It looks a lot better in my opinion than the add on fans offered for a lot more. Send me your email and I'll send some pics.
  #28
Old 05-01-2011, 08:18 PM
allwthrrider
well everything is in and hooked up , connected, rerouted, bolted,new instrument panel is in, driveshafts shortened, going to try and get out tomorrow and get the fluids, maybe Tuesday I try firing it off, wanted to long before now but life keeps getting in the way.
  #29
Old 05-04-2011, 04:52 PM
allwthrrider
Fired it off this morning little squirt of fuel in the carb wife turned the key & bang it was running,, at idle was pulling 80 psi oil pressure after 30 minute cam break in dropped to 70psi, I am using Royal Purple break in oil, should I be concerned about this high oil pressure?
  #30
Old 05-04-2011, 04:59 PM
Argess's Avatar
Argess
Argess is offline
The 80 psi at cold tells me that's where the pump bypasses, and that's good.
I don't think you can tell about the 70 psi at idle yet. Even though you ran it 30 minutes, the oil may not have heated up enough to thin out and cause the pressure to drop to an expected level as there was no load on the engine.
I'd say, go out and drive 5 to 10 miles and see that the hot idle oil pressure is.
Well,..er...make sure there are no weird noises first. Just in case something is plugged up. i.e. valves clatter as no oil to heads
Quick Reply: Did I make A mistake?
