Sponsored by: Real Truck
ZF5spd from a Gas vs. Deisel Differences?
Old Nov 11, 2010 | 12:48 PM
garvs350's Avatar
garvs350
Im in the planning a 12valve swap into a 2000 F350 that has the 5.4/ zf5spd. I was told that the diesel trucks had different gear ratios in the zf5 spd from a gas engine to a diesel but Im having a hard time finding that info. Also are there other differences in the tranys as far as torque ratings or input shaft/pilot bearing size. Any info. is very much appreciated guys!
Old Nov 11, 2010 | 04:31 PM
redford's Avatar
redford
FTE Leadership Emeritus
It doesn't answer your question but per Transmission gear ratios all the ZF-5 transmissions had the same gear ratios. so your source is incorrect.
