91 Explr: Battery Electrical Problems, Diagnose Help Needed
Old Feb 27, 2003 | 08:28 AM
RobinAgoura's Avatar
RobinAgoura
Battery was run down and would not hold a charge long. Driving home the Volt Meter on the dash went to 8vts and the Dash Battery light went on. SO I went to PepBoys and had a Battery installed. Car started up perfectly, But the Volt Meter is still at 8 and the Battery light is still on. Until I rev the engine to 3,000 RPMs then the Battery dash light goes off.....SO what do you guys think the problem is?
TIA.
Old Feb 27, 2003 | 08:43 AM
marshall0351's Avatar
marshall0351
your problem is most likely the voltage regulator on you alt, you can replace that or, if it were my 91 explorer with what ever miles on it i would replace the altenator assy. depending on if you buy new or reman it may or may not come with the regulator already installed. now replacing the alt. is quite a bit more money but do you want to take a chance in dealing with this problem again in which case you might have to replace the alt. anyway. sincerely scott
Old Feb 27, 2003 | 09:14 AM
RobinAgoura
is there any place on the net that details (hopefully with photos) on how to replace the altenator/Regulator on an Explorer?
Old Feb 27, 2003 | 09:26 AM
mrshorty's Avatar
mrshorty
www.autozone.com has repair guides on their website. Should have a reasonable set of instructions there.
Old Feb 27, 2003 | 09:30 AM
marshall0351
i don't know about any links with photos or not but, what you'll need to do is first disconnect the battery, then removed the drive belt, then dissconect the wiring, and unbolt from mounting braket. normaly it's held on with two-three bolts. (depends on year of make and i can't remember which your year of make was). after that the regulator is mounted on the rear with 4 torx bolts, t20 i believe. and out comes the regulator and brush set. i realy suggest replacing the alt assy at this time if you can afford it just because of the age of alt. if it's original. hope this helps sincerely scott.
036.0stroke
Sep 25, 2013 10:07 PM
jon705
Electrical Systems/Wiring
Apr 14, 2013 10:21 AM
BLADE35
Sep 22, 2010 12:50 AM
tlk50
Feb 23, 2010 05:37 PM
kawa
25
Sep 3, 2007 08:59 AM
