Sponsored by: Real Truck
Pulling problem...
Old Nov 11, 2010 | 01:38 AM
dyhrdford's Avatar
dyhrdford
Pulling problem...
Hello again guys, I have yet another problem. My truck is pulling to the left almost all the time. The only time it wants to go straight is when I am in the the RH lane. I have checked all the obvious causes of pulling: tire pressure, worn steering components, suspension components, brake drag, and alignment. The ONLY other thing I cam think of is the steering box??? Can anyone give me any other ideas please?
Thanks,
Aaron
Old Nov 11, 2010 | 02:02 AM
jhooch's Avatar
jhooch
If you haven't already, try crossing the front tires side to side and see if it pulls the other way, could be a radial pull in a tire.
Old Nov 11, 2010 | 06:47 AM
Rick03F250's Avatar
Rick03F250
Does it happen all the time or just on one rd.?
Depending on where you live, some roads are crowned that way for drainage.
There's a couple of roads I run on that does the same thing. Drove me nutz trying to fig. out WTF was wrong. Finally I gave up and blamed it on the roads.
Old Nov 11, 2010 | 06:50 AM
Rick03F250's Avatar
Rick03F250
Oh yeah, you could have a hub sticking too.
Old Nov 11, 2010 | 02:29 PM
mwsF250's Avatar
mwsF250
X2. I've had this happen many times.... Tires are not as consistent as you would wish.
Old Nov 11, 2010 | 04:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
Manually lock the front hubs (without putting the T-case in 4 wheel drive) and go for a spin. If the pull is gone then the hubs are the issue.
