Interior Parts replacement
Old Nov 12, 2010 | 04:07 PM
planehunter's Avatar
planehunter
Hey Thomas, What I did was take my carpet out of my truck and then rented a water extraction type carpet cleaner from a tool retal store, not from the grocery store. The extraction carpet cleaner has 2 motors for extra power. I then put the carpet on the ground, soaked it througout with concentrated spot remover and let it sit about 10 minutes. I did this on a tarp so the carpet wouldn't pick up any dirt. I then got on my knees and hand scrub it with a NYLON brush. Don't use a super stiff brush or you can tear the carpet fibers. Then I hosed it down with clear water and let it sit another 10 minutes. I then used the hand apholstery attachment and pulled up as much water as possible. I hosed it down again and repeated. Flip carpet over and vacuum padding to pull out more water. Hang to dry for at least two days. Test cleaner first for color fastness before proceeding. Be carful not to hang in high heat, migh cause your carpet to shrink. Mine was almost like new. Reinstall.
Old Nov 23, 2010 | 11:04 PM
hillbilly cajun's Avatar
hillbilly cajun
interior trim
I have a 94 F250 with the XLT interior. I have not been able to find a drivers side power seat housing. Any help appreciated, no luck local. Need a few other interior parts as well.
Thanks
Old Nov 25, 2010 | 12:40 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Ok guys, whnat about a dash?....my dash is cracked around the vents, and the removable pad is cracked also.....the replacment from LMC Truck is $139, but it looks like its just the top-which is where mime is cracked, but from what I've seen of the dash, it is all one piece, except the instrument cluster bezel and the pad on the passenger side....anyone have any info?
Old Nov 26, 2010 | 03:37 PM
mojo79's Avatar
mojo79
Planehunter...Thank you! sounds like that will work out great.
Old Nov 26, 2010 | 05:48 PM
SouthernBlues's Avatar
SouthernBlues
I have some Door Panels. 2 Blue and Brown
Old Nov 26, 2010 | 11:44 PM
Semper Fordelis's Avatar
Semper Fordelis
Hey Mojo,
I just took the carpet out of my 89 crewcab and soaked it with 6 cans of 409 carpet cleaner.....let it soak for 20-30 mins...then took it to the quarter wash. I sprayed the floor of the bay to be sure it was clean, laid the carpet down and sprayed it with the "rinse" setting. I threw the carpet on a fence to dry. It took out ALL of the stains and 3 weeks later it still smells fresh and clean! Total it cost me less than $15.00.
Old Nov 30, 2010 | 07:09 AM
mojo79's Avatar
mojo79
Just for reference to those buying new carpet... I ordered mine from ACC. I got the think premium stuff with extra backing. it was a little expensive but it is great quality. it has a thick rubber back under the carpet as well as the cushion stuff. With this type of quality, you could probably not worry about adding extra products for sound deadning.
I have not ordered door panels yet, but I'm thinking about Coverlay.
Old Nov 30, 2010 | 11:32 AM
Semper Fordelis
Glad your happy with the purchase Mojo!
Old Nov 30, 2010 | 12:35 PM
Diesel_Brad's Avatar
Diesel_Brad
For the complete dash you will need to go to a junk yard or FOrd
Turx's Avatar
Turx
Try NPD, they carry a lot of OEM, and Repro items. They use "Ford Tooling" on much of their Repro stuff. While LMC has the door panels, I don't like the way the panels fasten to the door, you can see the fasteners. NPD has ones that mount just like the factory, hidden fasteners, look factory. They also offer Catalogs for the various Ford body styles including one for 92-96 (inc 97250HD), fast shipping too.
Old Nov 30, 2010 | 01:40 PM
SideWinder4.9l
Thanks Diesel_Brad, but I'm just gonna order the replacement from LMC....Gonna fiberglass my tachometer and a 2 1/16" gauge on the right side of my dash....And as far as a definitive line from where the pad actually lays across the original, I will just fiberglass it together....
Old Nov 30, 2010 | 01:57 PM
Diesel_Brad
Why not just put a factory tach in?
Old Nov 30, 2010 | 02:10 PM
  #28
SideWinder4.9l
Already had it...And just want something no one else has....
Old Nov 30, 2010 | 03:20 PM
  #29
Turx's Avatar
Turx
Did you look at NPD? Their prices are the same as or very close to LMC, but the parts are much closer to or OEM parts. No, I don't work for them, but have been very happy with everything I've bought.
Old Nov 30, 2010 | 03:34 PM
  #30
SideWinder4.9l
I have NPD catalog....Unless I need a specific/hard to find part, I am just gonna use LMC...NPD seems to have higher prices....As far as quality I don't know about, as I haven't bought anything from NPD...
