Sponsored by: Real Truck
2000 5.4 head gaskets
Old Nov 10, 2010 | 09:59 AM
99F250Iowa's Avatar
99F250Iowa
I'm going to be replacing the head gaskets on my 2000 F250. Any recommendations on gaskets to get? Gasket kits? I have seen Felpro has permadry gaskets or permatorque with the metal reinforcements in it. I have heard the permatorques are the way to go but wanted some opinions. Also going to replace the timing chains while I have everything torn down.. along with the head bolts. Any recommendations on any or all of these items and where to get them?
Old Nov 10, 2010 | 11:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is this a stock rebuild or for a performance application?
Old Nov 10, 2010 | 01:48 PM
99F250Iowa's Avatar
99F250Iowa
Just stock rebuild. I dont use the truck to pull anything or push snow. Just haul stuff in the bed from time to time. I'm just looking to fix the leaking gaskets with a quality fix. I don't drive the truck a whole lot so I don't want to pour a bunch of money into it that's not necessary for what I use it for. But, I dont want to go a cheap route and have it leak again down the road.
Old Nov 10, 2010 | 03:34 PM
redford's Avatar
redford
Standard gaskets and timing chains should be fine. Make sure the heads and block are checked for level mating surfaces before the gasket is installed. Correct as needed.
I like ARP products for holding the head down, but that is just my preference.
Old Nov 10, 2010 | 05:08 PM
mwsF250's Avatar
mwsF250
I used Ford parts from Ed.
Frankmyers
Feb 10, 2015 09:49 AM
99F250Iowa
Modular V8 (4.6L, 5.4L)
Nov 19, 2010 01:27 PM
holdendaniels
Nov 13, 2010 03:11 AM
fordeverpower
13
Jul 24, 2008 01:25 PM
19903934x4
Sep 6, 2007 11:48 AM
