But before i need some help with two little Fuse Boxes near the engine compartment in addition to the Central Fuse box, there are two fuse boxes for relays for which things they are ?
And the greatest problem are the power door lock actuators, if i push the switch, the actuators would be work but, they are to weak and they can´t close or open the door , i can hear it they will be work, but if i push the switch more than once, the actuators will be more weakly and at the end (push it five times) i can´t hear the actuators. Are the actuators to weakly ? too lower voltage ?
The Car is: a Ford F250 1999, XLT, Super Duty
I hope you can understand me, and so i hope you can Help me
Welcome to the forums! I had this issue with some actuators in my Jeep, they were just dirty and needed a good cleaning. Or the locking motor was dirty at least. I cleaned them up and they worked more freely. I also had this problem on the rear hatch on my excursion, after a good and thorough cleaning session it freed up and worked with no problems. Habt einen guten Tag. Hoffe, das hilft.
Hi bigbear. It doesn't look like you went to the "Read First" folders at the top of the listings here. If you did (the one for the tech folder), you would find this link in there:
You found the best forum anywhere. Stick around and you'll learn more than you can imagine. If the thread is too wordy and throws you, shoot me a private message and I'll try to walk you through it. By the way, I happen to have two new actuators for the drivers side if you need them. I needed passenger side, but ordered wrong. Where are you located?
