drive shaft bal???
Old Nov 8, 2010 | 11:10 AM
rcgtsport's Avatar
rcgtsport
drive shaft bal???
i checked support bearing moves almost 1/2 inch so stared to take off when 2 bolts on cap were rounded off. in a hurry i removed center bearing an then unbolted from tranfercase. now my problem is forgot to mark drive shaft before seperating it will that cause balance problems? do i just go to napa for parts take chance or spend twice to have it done at drivshaft shop? any in south jersey lower ocean co ?
Old Nov 8, 2010 | 12:31 PM
clem1226's Avatar
clem1226
IIRC the slip yoke is keyed so it will only go back together one way, you should be fine.
Old Nov 8, 2010 | 04:59 PM
rcgtsport's Avatar
rcgtsport
i just looked at mine, yoke is not keyed. e99 f350 cc lb drw
Old Nov 9, 2010 | 07:56 PM
rcgtsport's Avatar
rcgtsport
napa support bearing
went to napa today got 3 u-joints and a support bearing. the support bearing is a little smaller than what was on it bearing size would be the same will it make differants.
