Put a F250 4x4 front suspension in a F150 4x4 truck frame
Old 11-08-2010, 07:48 PM
Duramaxfanatic1's Avatar
Duramaxfanatic1
Duramaxfanatic1 is offline
Originally Posted by Diesel_Brad
F150-F350 2wd TTB coil sprung
F150 4wd D44 coil sprung 5 lug
F250 4wd D44/D55 leaf sprung 8 lug
F350 4wd D60 leaf sprung 8 lug
F-superduty Solid I-beam leaf sprung 10 lug
so no coil sprung f-250 4x4's? i think i read once someone had to use a chevy hub and fit it on the front? what is the difference between an 8 lug d44 land d55? ive been wanting to convert to 4x4 for some time and use the spring/shock towers from a bronco for the dual shocks, and still have the ttb coil sprung not leaf sprung. also i have a anti roll bar from an f350 2wd would i be able to carry this over to a 4x4 conversion?
Old 11-08-2010, 09:52 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,171 Likes on 925 Posts
The Bronco guys have some great info here: Fullsize Bronco Solid Axle Swaps
Old 12-22-2010, 06:36 PM
Turx's Avatar
Turx
Turx is offline
Don't forget the 97 LD F250 and the "7700"GVR's...150's that have 7 Lugs.
Old 12-22-2010, 06:54 PM
big-ugly's Avatar
big-ugly
big-ugly is offline
[quote=Duramaxfanatic1;9535940] ive been wanting to convert to 4x4 for some time and use the spring/shock towers from a bronco for the dual shocks, and still have the ttb coil sprung not leaf sprung. [quote]
Why not find an f150 with dual shocks and have everything for the swap over? Unless you want the extra lugs, I don't believe that there is a difference in the TTB (correct me if I am wrong). The differences are minimal. Unless you are saying you have the bronco already for parts? or can get it cheap? It is not necesary to use a bronco front end, my 89 has dual front shocks (all four shot at the moment...) All it really does is makes it more expensive when they need replaced, cause you gotta get 4 instead of 2. Not really noticed a good reason to have 4 instead of 2 in the front. Just my .02
Sorry, just noticed you have a f250. Now I understand why you would want the 250 hubs and the extra lugs.
POLARISrider500
02-12-2016 11:35 AM
fordguy98
Texas Chapter
12-03-2015 07:43 PM
phoneman91
07-27-2015 07:53 PM
chadaboon
03-11-2015 09:54 PM
brianslawncare
11-09-2013 08:52 AM
Quick Reply: Put a F250 4x4 front suspension in a F150 4x4 truck frame
