Need Help
Old Nov 6, 2010 | 11:42 PM
riverrat2's Avatar
riverrat2
Need Help
I have been having this problem with my 1992 302 for a while now and it just recently got worse, even the slightest bump will cause it to cut out. At first i thought it was my in tank pump, but i replaced that and the problem continued.
So I assume it must be an electrical problem. I took off the bed to double check all the wiring under there, everything seems okay there. I found what I think is the EEC relay and tried tapping it and a few other relays on the master cylinder to see if the problem would come back, but no luck there. If I shake the truck hard enough it will start to cut out as well.
Anyway I could really use some help here if anyone has any info on problems like this i could use it!
Also tranny shakes really bad when going into overdrive
