Sponsored by: Innova
CD Player Installation
Old Feb 26, 2003 | 05:36 PM
jobeck's Avatar
jobeck
Question CD Player Installation
I recently installed a JVC El Khameleon CD Player in my 2000 F-150. When I took out the old cassette player I noticed that there were 2 connectors instead of one. In doing some reading online, I found out that the smaller of the 2 was for the amplifier. My question is this. I hooked up the new player to just the larger connector with a wiring harness and it seems to work fine. What, if any, benefit would I get if I used the amplifier that Ford provided? The only thing that doesn't work as advertised is the dimmer for the radio, any ideas on that?
Thanks for the help.
Old Feb 26, 2003 | 06:42 PM
e_no_g's Avatar
e_no_g
As far as the amp is, your JVC probably has mre power than your factory amp, so there may be not benefit to use your factory amp. Now as for the dimmer, make sure you hooked up your dimmer wire from the harness, it should be orange with a black or white stripe. If you did, and it still doesnt work, try the illumination wire also.
Old Feb 26, 2003 | 06:53 PM
jobeck's Avatar
jobeck
What do I do, combine the dimmer and the illumination wire together?
Old Feb 27, 2003 | 01:12 AM
e_no_g's Avatar
e_no_g
Try each seperately. and if they dont work, try together, it wont hurt anything, because they are both a positive wire.
Old Feb 28, 2003 | 10:00 AM
e_no_g's Avatar
e_no_g
They are both a NEGATIVE not positive.
Old Feb 28, 2003 | 03:09 PM
jobeck's Avatar
jobeck
Thanks!
Old Mar 2, 2003 | 06:59 PM
smokey6309028's Avatar
smokey6309028
Just checking to see if you got the problem with the dimmer function working, or if you would like more assistance ?
Steve
boxcarracer955
Apr 11, 2015 08:55 PM
FTISCAR
2004 - 2008 F150
Nov 13, 2006 04:23 PM
THEBOOGIEMAN
Sep 13, 2006 08:07 AM
